help identify part, c654 (part number)
  • TEST10
    • Jun 2010
    • 69
    sensor.jpgplease, i need the part number of the actuator of the sensors that are entering the fuser of a KM c654.
    that piece falls apart practically impossible to repair, and in the second-hand market already exhausted..
    I would greatly appreciate your help
  • KMFLT3CH
    • May 2017
    • 240
    Re: help identify part, c654 (part number)
    Hope that helps.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4709
      Originally posted by TEST10
      [ATTACH=CONFIG]54526[/ATTACH]please, i need the part number of the actuator of the sensors that are entering the fuser of a KM c654.
      I just posted about this same thing recently. Search this forum there was a lot of good information about this rotation sensor. It's not that hard to replace. But you do need to get some of those covers as well because the tabs break from the heat when you remove them.
      • TEST10
        • Jun 2010
        • 69
        Originally posted by KMFLT3CH
        [ATTACH=CONFIG]54529[/ATTACH]
        [ATTACH=CONFIG]54530[/ATTACH]
        Espero que ayude.
        Thank you very much, reviewing the part numbers I found this publication prior to the rest ...
        thanks again
        C654e jams - actuator removal?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4709
          thanks again
          That is my post I was talking about
          • TEST10
            • Jun 2010
            • 69
            thanks it was very helpful
