Konica minolta c452 light print at bottom
  • irokkas
    • Oct 2012
    • 18
    [Misc] Konica minolta c452 light print at bottom
    Hello to everyone,
    As you can see at the bottom of the printed image there is a difference on the color.All the pcu's are relatively new (15k).I think the problem is when the printer is mixing colours, so my mind is on laser unit.I would appreciate your thoughts
  • allan
    RTFM!!
    • 5462
    Re: Konica minolta c452 light print at bottom
    Originally posted by irokkas
    Hello to everyone,
    Also post half tones at value 125.
    The age of the rest of the consumable parts?
    Is that on the leading or trailing edge? Looks like the trailing edge. Could be secondary transfer. Retraction timing, roller and belt condition or even fusing speed.
    Whatever
    • copyman
      Owner / Technician
      • Sep 2005
      • 4717
      I would try removing and cleaning the laser PH. Could also be a drum problem even with 15K, especially if the drums are old.
      • techsxge
        • Jan 2022
        • 660
        Can you explain how you got to this? I cant explain this to myself.
        This looks more like drum unit or mb Developer
        • irokkas
          • Oct 2012
          • 18
          Tried another laser unit + transfer belt unit and nothing changed.After that the machine gave me another hint!There is magenta toner at the bottom.Also the client now told me that a few weeks back a document printed with full magenta background ( from edge to edge) and after he powered of the copier started to printing ok. So the problem probably is the magenta IU
          • Gift
            • Mar 2011
            • 2459
            Hard to judge these low quality samples since they are looking quite okay-ish to me (for a machine this old and - probably - wasted and or over-aged consumables^^).
            • techsxge
              • Jan 2022
              • 660
              Check Magenta and Blue drum + Developer.
              Or is this aftermarket Toner?
              • irokkas
                • Oct 2012
                • 18
                the first one is with only magenta and the second is only cyan
                  • 23009
                  There is still confusion about which direction these pages fed. I've attached A3 sized images. I think that we could tell more if you printed these A3 sized images, then attached photos or scans of the results: =^..^=
                  • allan
                    RTFM!!
                    • 5462
                    Not enough initial info so I assumed to feed direction...
                    I got the feed direction wrong and everything else followed.
                    Whatever
                    • tsbservice
                      Field tech
                      • 8020
                      It costs a fraction of the second to draw an arrow pointing towards paper feeding direction but who am I to assume 😅
                      • irokkas
                        • Oct 2012
                        • 18
                        Ι m sorry for the confusion.Most of them have a red background.Thank you all for the help.
                        • techsxge
                          • Jan 2022
                          • 660
                          I am still vouching for the Magenta and Cyan Drum/Developer Unit. Can you send Photos of it?
                          I have seen this problem a bunch of times and in 60% of the cases its the cleaning blade (Is that the correct name?) of the Drum Units, 30% of the time its low developer and the last 10% are other parts like fusing unit or transfer unit
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4717
                            I would start with at least the Magenta Image unit. Or split the IU open and clean corona, etc. Maybe add a little aftermarket developer.
                              • 23009
                              I agree. Magenta IU for sure. Cyan IU to a less extent. Actual image count becomes inconsequential after a year or two has passed.
                              Having those images definitely helps. =^..^=
