Black header blue text body
  • positiveg
    • Jun 2018
    • 299
    Yet all the text is black.
    My c454 is doing this and I'm not sure why.
    I've already fone several image stabilization on bit. The drums are new. It hasn't been in use for a while because it kept jamming. I decided to turn it on tonight and run it and it's doing this.
    And it happens specifically parts of the booklet and paper.
    Any advice?
    Hope everyone is doing well
    Sent from my SM-G780G using Tapatalk
  • femaster
    • May 2011
    • 1492
    Re: Black header blue text body
    I would start by making absolutely sure the text is in fact black and not a really dark blue (that looks black on a PC screen) in whatever document you are printing it from.
    Next step would be to fill us in on what program you are printing from and what the file type is.
    • positiveg
      • Jun 2018
      • 299
      Yes ita black and using PDF
      Got it straight from customer
      Will try another file and see.
      Ok I changed the cyan drum it has improved. But that drum had an issue so ita still a bit cyan bar at the bottom.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        • positiveg
          • Jun 2018
          • 299
          I really it only shows up like that. Other files too in pdf prints like that. Butbits strange as we have some files print ok.
          I was able to get the blue bar sorted cleaned the lens.
          The text though especially when it's like a paragraph is not as sharp and has some blue in it.
          Will try to do a lot of copies and see what hapoenes. Out other printer is printing the same files nice. (XEROX C75 AND OHASER 7800)
          • Synthohol
            Certified Konica Expert
            • 5809
            when i suspect composite black issues i print the file in grayscale to see if the black is light where it should be dark.
            id still reset and stabilize then run gradations. this may get rid of the blue haze
            • Gift
              • Mar 2011
              • 2459
              To rule out the printer:
              Try print some full page test prints with only Cyan (and the other color's while you're on it) - full bleed and half tone.
              And looking at the PDF file:
              Also make shure to print from acrobat reader not any 3rd party application or browser plug in.
              You can try select print "PDF as image" test wise.
              In case it's a file issue: "Got it straight from a customer" isn't really something I would rely on LOL
              That font that is suppose to be black isn't obviosly black - even a slighty "colored" black will look like solid black but the MFP will try and mix it from color,
              this usually end up with blurry text-edges.
              • positiveg
                • Jun 2018
                • 299
                Will try this out and let you know
                • positiveg
                  • Jun 2018
                  • 299
                  Yep I ran some cyan prints nothing at all on the drum like perfect
                  • allan
                    RTFM!!
                    • 5462
                    You can also use something like CutePDF "PDF printer" to remake the PDF and see if that makes a difference.
                    Whatever
