Good evening, has anyone ever changed the fuser swing unit or try to fix some parts on it ? there is no procedure to do this ...
C3070 Fusing Swing Unit
Re: C3070 Fusing Swing Unit
According to the manual there are factory adjustments to the fuser swing unit that cannot be duplicated in the field. Why do you need to change it?If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
There is a malfunction (C3303) to the fans due to a customer fault ...and it needs to be changed ...
Best regards
NickComment
All that I can suggest to you is to carefully scribe & mark each of the slotted adjustments and attempt to reposition the new part in the exact same place. I'm assuming it's the alignment of the fuser in the paper path that's critical, but there may be additional reasons for the adjustments.
Watch for wrinkling of the paper & paper skew (especially second side).
I'll be interested in the results. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Hi, hope, it's help.👍 1Comment
👍 1Comment
Indeed, I've also found that if you remove the finisher and exit unit from the machine, that the rear section of the swing unit is really easy to get to. Providing that the machine doesn't have a circus train of accessories attached to it. Change that one way exit pressure gear while your in there.Comment
