C3350i painel glass
  • Tiagocang
    • Feb 2022
    • 62
    C3350i painel glass
    Sup, i got 1 C3350i/4050i and the cliente broke the painel.... The Touch work fine, just wanna know if the glass can be change or any tip where i can get glass ONLY or compatible glassPSX_20220926_132425.jpg
    • 23006
    Re: C3350i painel glass
    It's not just glass. There's a glass base with mylar sheets over the top of the glass that serve as a touch panel. So the answer is No.
    Konica Minolta only sells the operation panel as an assembly. =^..^=
    • Gift
      • Mar 2011
      • 2459
      Correct, you can charge the entire panel assy.
