FS-539 Mandatory Modification Bulletin Issued by KM
  • femaster
    • May 2011
    • 1526
    KM just issued a technical bulletin for mandatory modification of the FS-539 finishers. Apparently they were assembled incorrectly at the factory which results in misaligned output when stapling. It looks like it's going to be a fun modification. Not looking forward to doing this at all...
  • tsbservice
    Field tech
    • 8064
    Re: FS-539 Mandatory Modification Bulletin Issued by KM
    Thank God we don't have one. Looks like a lot of fun involved-springs, grease, tight spaces and possibly damaged FS. What a great QA though!
    • L0rdC
      • Feb 2021
      • 82
      I'm not surprised at KM, really...
      • copyrooks
        • Oct 2013
        • 210
        The techs should get the reimbursement directly from konica. Waste of time
        • mojorolla
          The Wolf
          • 2639
          $108, great compensation KM. They should have set fire to the entire i Series machines instead of their toner plants.
          Par for the course with KM as of late.
            • 23010
            Can be the defect be seen before you start disassembly?
            It would be really disappointing to spend two hours disassembling the finisher ... only to discover that you never needed to. =^..^=
            • occus
              • 338
              I think so.
              Have a look to the right roller from outside. The passiv white roller should have a distance from the right margin... you should see the metall axis. If not then the roller are misalignet to the grey active rollers with the spikes.
              Or on Pic 2 you can check the distance of the 2 middle rollers, they should be not to close to each other.
                • 23010
                Is that the metal guide shaving off the rubber? That's fairly obvious. It sounds like you need to have a new set of rubber rollers on hand before doing the bulletin. Thanks, occus. =^..^=
                • rrrohan
                  • Sep 2011
                  • 1977
                  you can by serial number
                  FS-539
                  AAR4WY1031758 - AAR4WY1035182
                  FS-539SD
                  AAR4WYA022846 - AAR4WYA025403
                  • femaster
                    • May 2011
                    • 1526
                    There is a serial number range listed in the bulletin. Also, any that were produced after the problem discovery, and have the rollers installed properly, will have a "green label" attached to them.
                    • occus
                      • 338
                      Ah it's only dirt... There is enough space... maybe after the modification
                      As they always write so beautifully "Reassembly the FS-539 by reversing the installation instructions"
