Slowly going mad ... Bizhub c454e doesn't want to print on 4x6 postcards?
  • frood
    • Sep 2022
    • 18
    Hi all,
    Short background on me> sysadmin, webadmin, hacker, car-fixer, HVAC tech, 3-D printer nerd.
    Trying (in vain...) to print to 4x6 postcards from a 4x6 postcard file.
    I have followed the instructions for printing postcards in the online manual, here:
    Changing the Paper Size or Type
    [SEE BOTTOM OF POST IF YOU LIKE LABELED APPENDIX A]
    HIT PRINT IN POWERPOINT
    As per directions (above), I set the PRINT SETTINGS in the driver.
    (see attachments)
    And set the PAPER SETTINGS FOR EACH TRAY
    (see attachments)
    I load a chunk of 4x6 into the bypass tray, and hit PRINT.
    RESULT:
    I keep getting this error: (note: there is no paper in Tray 1, and I'm setting BYPASS TRAY in the print dialog settings.)
    "Unable to feed current Thin Paper size. Select from the following paper size(s).
    : Longer than 6 inches"
    If I go to the printer, hit COPIER, I can adjust the paper, but if I select 4x6 Postcard, I get THIS error:
    HHHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALLLLLLLLLLLLLLLLL LLLPPPPPPPPPPPPP!
    I'm clearly missing something. Assistance would be greatly appreciated. Thanks in advance!
  • Gaffers01
    • May 2011
    • 335
    Re: Slowly going mad ... Bizhub c454e doesn't want to print on 4x6 postcards?
    Have you checked the sizes on the photocopier as this must match the size you are trying to print.
    Try photocopying from that tray (bypass) and see if it comes up with the same error.
      • 23010
      I suspect that your Microsoft application is holding a previous print setting, over-riding the print driver setting, specifically THIN media type or tray #1 paper source. Its not uncommon on Microsoft apps. Try converting your page to PDF before printing. By all appearances your print driver settings are correct. And to my surprise ... yes, 4" x 6" SEF cardstock is an acceptable media size & weight. =^..^=
      • emujo2
        • Mar 2017
        • 1579
        Empty the trays and bypass, send the job again designated as bypass. You should get a message "load X by X paper (plain, thick ect)..put the media in the bypass tray and let the machine know. If the guides are adjusted correctly it should pull from the bypass tray
        Edit** tray 1 is designated 5 1/2 by 8 1/2 thin, and the machine is trying to pull from there..I think the Cat is correct..Your job properties are overriding the driver settings..Take a look at the per page settings..
          • 23010
          I'll also suggest going mad more quickly. You'll suffer less.
          At a certain point I you really start to enjoy going mad. =^..^=
          • frood
            • Sep 2022
            • 18
            Along the same lines:
            • Gift
              • Mar 2011
              • 2459
              Is that office document also 4x6? The document format/size info can override the driver setting and cause size-conflict error messages.
              But your message is a bit weird - it's actually referring to the paper type. Driver settings looks OK but you need to set the paper type on the printer, too.
              You can do that from copy screen, just select the bypass und from there you can adjust the sick... ehrm thickness^^
                • 23010
                Have you made any progress, frood?
                Printing your cards, or going mad? We're all curious. =^..^=
                • frood
                  • Sep 2022
                  • 18
                  SOLVED: Slowly going mad ... Bizhub c454e doesn't want to print on 4x6 postcards?
                  I posted a response some time ago, but it didn't appear for some reason.
                  Evidently the error message was UNRELATED to the bypass tray paper size. While trying to get the machine to accept the 4x6 postcards, I had moved the guides of Tray 1 (internal) so that they were smaller than the minimum paper length of 6" for that tray.
                  The issue:
                  Even though the tray was not being used for anything and empty of paper, the fact that the guides were in such an "impossible" configuration caused an error that pre-empted using the machine at all.
                  The solution:
                  Was just to move Tray 1 paper guides back to a standard size 8.5x11 (an acceptable/possible paper size). As an acceptable paper size, it cleared/prevented the error. Without the error, following the 4x6 printing directions as written in the manual worked fine.
                    • 23010
                    Well that is interesting! Thanks for sharing. =^..^=
                    • tsbservice
                      Field tech
                      • 8052
                      Re: SOLVED: Slowly going mad ... Bizhub c454e doesn't want to print on 4x6 postcards?
                      The issue:
                      The solution:
                      Isn't picture 3 saying the same?
                      • frood
                        • Sep 2022
                        • 18
                        SOLVED ... Again... lol.
                        USER ERROR: Interface misunderstanding.
                        I still had problems from time to time with this, but it was a misunderstanding of the COPIER BEHAVIOR and INTERFACE.
                        Symptom: (from my perspective...)
                        I would try to print 4x6 post cards...
                        The START button would get the orange surround and the interface would display "please reset the Bypass tray using the correct paper size" on the bypass tray.
                        I would look at the bypass tray in the display which indicated 5.5x8.5 paper, which is not 4x6.
                        I would press the on-screen bypass tray button that indicated 5.5x8.5 paper ... and the only option was to select that same size, not 4x6.
                        :: Confusion ::
                        "reset the tray? didn't I set it correctly?"
                        "using the correct paper size? but I _did_ put the correct paper size in the bypass tray?
                        Removing and replacing the paper did not help.
                        Solution:
                        Assuming that you already have 4x6 in the bypass tray, just press the START button.
                        It is just saying "my dude, is there 4x6 paper in the bypass tray? yea? nay?"
                        Behavior I wasn't understanding:
                        This happens the FIRST time you go to print 4x6 (or any other size it can't automatically sense).
                        Requirement: The paper printed LAST TIME in the bypass tray paper size on the print before was DIFFERENT than 4x6. (size, weight, labels...)
                        (note: the attached photo shows 4x6 in the bypass ... but I had changed from THICK 2 to THICK 1; the behavior is similar)
                        The machine is JUST trying to be SURE that you put the right paper in the bypass tray before it prints.
                        Even though I really do think this is a language use/meaning problem with the GUI/UX team ... HOLY F--K, I FEEL STUPID.
                        I'm leaving this here in case it's helpful, and to provide evidence that you are not alone in your frustration, traveler.
                        • Larhal
                          • 616
                          Sometimes the answer can be right in front of our eyes. Thank you for sharing your problem and solution and of course your pride with us.
                          Larhal
                          If all else fails read the Service Manual!
                          If that fails, meet me at the pub and we will discuss it.
                            • 23010
                            Congratulations!
