Cyan halftone pattern color off
  • BWMMA
    • Sep 2022
    • 8
    [Misc] Cyan halftone pattern color off
    I have a Bizhub C558 that is having an issue with cyan. All other colors look fine, but the cyan halftone pattern is only printing solid cyan on the bottom but is light colored the rest of the way across the page (image attached) machine has "drum/developing unit error (C)" and stabilizer always says NG.
    What I've done already:
    -replaced cyan drum and developing unit
    -replaced high voltage board
    -replaced transfer belt
    -replaced FRB
    The problem still persists after replacing these parts, any ideas of what it could be?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Cyan halftone pattern color off
    Check the operation of the locking cams (connected to the blue drum locking lever) and ensure the developing unit is being pressed against the drum correctly.
    • Gaffers01
      • May 2011
      • 335
      Looks like a drum unit issue!
      Is it a genuine cyan drum unit or a black one changed to colour as i think you haven't taken all the right bits off
      • BWMMA
        • Sep 2022
        • 8
        @Gaffers01 - the cyan drum is a genuine drum from Konica Minolta. no chip swaps or anything
        • BWMMA
          • Sep 2022
          • 8
          @EarthKMtech - I'll take a look at the locking cams and I'll reply back afterwards to let you know if that was the issue or not
          • BWMMA
            • Sep 2022
            • 8
            @EarthKmTech- I checked the locking cams on the front-side and back-side. Both lift up fine and levels dev. unit with drum, but the issue still persists.
            • Gaffers01
              • May 2011
              • 335
              Try swapping the yellow drum in there and see if that makes any difference?
              if not swap the yellow developer unit with the cyan and see if it makes any difference?
              • BWMMA
                • Sep 2022
                • 8
                Thank y'all for the help, I just figured out what was causing the issue. I pulled out the new transfer belt I installed and a piece of plastic was broken near the cyan pressure roller in the belt causing one side to not make contact (pictures attached) the left side picture is where it broke and the right side picture is what the other pressure roller spots that aren't damaged for comparison. I put a used transfer belt in and cyan prints like it should. The new transfer belt must've came damaged in the box.
                • tsbservice
                  Field tech
                  • 8053
                  [ATTACH=CONFIG]54844[/ATTACH][ATTACH=CONFIG]54845[/ATTACH]
                  That's some bad luck. So you probably first replaced ITB unit and then start chasing your tail....
                    • 23010
                    That kind of damage can occur when removing or installing the primary transfer belt unit. I saw it especially on the xx4e series. It was necessary to remove a few pieces from the outer door to get the belt unit out. If a person were to just force it out ... that's what you get. =^..^=
                    • BWMMA
                      • Sep 2022
                      • 8
                      @Blackcat- nothing felt forced when removing old transfer belt or when installing the new one. It was damaged in the box and I didn't realize it. This has been my first time seeing this issue and I've replaced several transfer belts and this has never happened. I just have to make sure I check everywhere on new units for damage from now on. Luckily the 8 series and up don't have those door blocks on the right side anymore
                      • tulintron
                        • Jul 2014
                        • 668
                        [ATTACH=CONFIG]54822[/ATTACH]
                        -replaced FRB
                        You said you had changed.
                        • femaster
                          • May 2011
                          • 1519
                          I will concur with you on the out of box damage. We've probably had a total of about 4 belts of this part number, out of the multiple hundreds we've installed over the years, that have had one of the roller mounts broken right out of the box. It's very rare, but it definitely happens. I can't recall having the same issue with any of the other model belts, just those ones.
