Konica Minolta 951 FS-532
  • Aleksandar KM
    • Jul 2019
    • 13
    Hello,
    I have problem with FS-532 now it calls error C1001 communication error before this error we burned somehow 4 FNSCB.
    I order 2 new boards and i cant update firmware so thay are not working. The N on the ISW is not available.
    I tried this on 4 deferent machine with 4 deferent FS and with deferent versions on firmware.
    Any help pls what can i do ?
  • tulintron
    • Jul 2014
    • 668
    Re: Konica Minolta 951 FS-532
    Originally posted by Aleksandar KM
    Hello,
    I would look for some icp on the PRCB board.
    • wjurls
      • Feb 2017
      • 495
      My money is a short or open circuit for the interconnect wiring between the FS-532 and the Main body of the 951. The wiring that connect the finisher to the machine are often damaged from install and relocations.
        • 23006
        I'd check connector CN218 at the PRCB, and CN757 & CN894P (on the FNSCB going to the DCPS) CN755, CN756P, CN893 & CN895 at the FNSCB. Make sure that you have 5vdc voltage at CN757 (hot: pins 4 & 5)(grounds: pin 2 & 3) on the FNSCB. If the wiring is intact, and you've tried multiple FNSCB's, then I'd replace the PRCB, then update firmware.
        Communications errors can occur because:
        *no power to the finisher
        *poor connection at one of those connectors listed, or damaged harness
        *blown ICP as a result of plugging in the finisher with power live
        *damaged FNSCB as a result of plugging in the finisher with power live
        *damaged PRCB as a result of plugging in the finisher with power live
        In a very rare case, I had a dead short on a 5v sensor that was pulling down the 5vdc from the DCPS.
        You didn't mention: Does the base machine run, without a finisher? I would suspect No. =^..^=
        • tulintron
          • Jul 2014
          • 668
          Hello,
          04 FNSCB in the same Finisher?Can you tell what burned on the board? You may have a motor burning boards. Don't put it on without first finding the burnt component or the cause of it all.
          • allan
            RTFM!!
            • 5462
            That finisher board is one of the boards I managed to toast. You can get the square connector with 4 wires into the socket with 6 pins on the machine. I was hanging of the machine when I connected the finisher and managed to do just that.
            What firmware ver are you looking for?
            Whatever
