C458 + probably dead MFBP
  • Gift
    • Mar 2011
    • 2459
    Hey guys, my memory became a bit clouded when it comes to swapping USED boards on this series. We have a unit that won't boot up at all and already ruled out HDD/EMMC so we think the MFPB board is screwed.
    Since this customer has a service contract I'd prefer to pick a used board from a donator but the documentation doesn't really recommend that.
    My tech thinks he can run the reset tool on the parts donator, shut down the machine and take the resettet MFPB board to fix the customers MFP.
    Sounds like a good idea - what would you guys recommend?
    • 23010
    Re: C458 + probably dead MFBP
    I was not aware that the MFPB reset tool was available for the xxx8e series, but yes ... that should work. It works on the xxx4e series. Be aware that running the reset tool often ends up in a changed CE password, requiring that call to the hotline. =^..^=
    • 40yearsplus
      • May 2020
      • 113
      I have not had to do this but it sounds like it is worth a try since you are probably doing it to save money.
      You can always revert back and put the other board in if its giving you any type of function til you order the new one?
      • techsxge
        • Jan 2022
        • 660
        I also only have the reset tool for the xx4 machines but i used it on xx8 machines too before. Its a bit of gamble if the machine accepts it.
        • allan
          RTFM!!
          • 5462
          Just make sure to carry the EEPROM and EMMc(SSD) from the old board to the "new" board.
          Board replacement cases.pdf - Google Drive
          Whatever
          • techsxge
            • Jan 2022
            • 660
            Wasnt it like:
            1. Remvoe HDD
            2. Boot in Firmware Screen
            3. Update Firmware
            4. update Moviedata
            5. Enter Serials
            6. Reconnect HDD
            7. Profit
            • tsbservice
              Field tech
              • 8054
              +1. It's probably good at first to run reset tool on donor MFPB before putting in troubled machine but in my case it wasn't possible so yeah only swap 2 EEPROM & EMMC.
              • tsbservice
                Field tech
                • 8054
                • tsbservice
                  Field tech
                  • 8054
                  Originally posted by techsxge
                  Wasnt it like:
                  1. Remvoe HDD
                  3. Update Firmware
                  4. update Moviedata
                  5. Enter Serials
                  6. Reconnect HDD
                  7. Profit
                  Movie data(animation guide) resides on HDD
                  • adecanmin
                    • Oct 2010
                    • 321
                    This may help
                    • allan
                      RTFM!!
                      • 5462
                      If you move the EMMc end the EEPROM then you only really need to start with firmware if the version don't match no need for the reset tool.
                      Whatever
                      • tsbservice
                        Field tech
                        • 8054
                        Originally posted by adecanmin
                        This may help
                        This is for previous generation. 8 series a bit different.
                        • adecanmin
                          • Oct 2010
                          • 321
                          Good to know
                          • techsxge
                            • Jan 2022
                            • 660
                            This may help
                            this is the instruction for NEW BOARDS, not USED
                            • tulintron
                              • Jul 2014
                              • 668
                              it is a long, delicate and high-risk process.
                              Have all the necessary fws on hand. I think it's 05 Fw. After using the reset tool, the board to be used will be considered new, so follow the steps for a new board.
                              I only did this once in Series 8. I was successful.
                              But before that, it went very wrong and took me 03 days
