Bizhub C550i restarts on logo screnn
  • nevern
    • Dec 2021
    • 1
    Hi all.
    I have a bizhub C550i that does not boot up. It displays the logo and the loading bar goes to 25% and restarts. I tried to boot up with firmware but it does the same thing. I have changed the CPU board and tried another Storage board.
  • Max
    • Oct 2011
    • 561
    Re: Bizhub C550i restarts on logo screnn
    Try disconnecting all the options. (fax, trays, DF and so on) Then the control panel and main board (Baseboard (BASEB) Format the storage and initialise all in the service menu.
    • tsbservice
      Field tech
      • 8020
      Originally posted by nevern
      Hi all.
      You should update Firmware with correct version(for machine with or without A800 memory). Try many times (5-6 at least). If you still can't boot machine run diagnosis and recovery tool for bootup issue for this model. The problem is with firmware I think.
        • 14813
        Hi all.
        I have seen this symptom on a couple i series machines and it ended being a faulty storage board.
        • tsbservice
          Field tech
          • 8020
          This is similar but not the same problem. He changed storage board. I suspect another KM bitter failure.
          Author, do you have fuzzy/blurred/double display at some point?
          • Woxner
            • Jul 2011
            • 851
            was the storage board new or used. You cant use a storage Board from another machine. serial , meter. and firmware are stored on these. its not like the old HDD.
            • tsbservice
              Field tech
              • 8020
              In fact you will get an errors but after machine boots.
              • Synthohol
                Certified Konica Expert
                • 5849
                i would run the GXX diagnostic/recovery fw TOOL
                it should help.
                if you boot holding down the yellow button in the back of panel it should go into trouble reset mode and see if you can access the trouble counter to see what code.
                • Gift
                  • Mar 2011
                  • 2459
                  Yeah "Another" storage board sounds like it had a history. I currently have 5 storage boards with 25% boot issue in my drawer waiting for a fix to revive them, unfortunately the only way to fix it is using the reset tool but with that method you'll loose everything including counter data.
                  • tsbservice
                    Field tech
                    • 8020
                    can't You put them in brand ne machine and use reset tool?
                    • rrrohan
                      • Sep 2011
                      • 1977
                      do u have the long nvme drive or the short one? u want the short one cause know issues with the longer/old type
                      • Gift
                        • Mar 2011
                        • 2459
                        Haven't thought about but it sounds like a promising good idea. Guess the workflow should look like this:
                        - Run reset tool on new MFP with used/faulty STRB from my collection / don't reboot
                        - Remove storage board
                        Guess I can try that and before fixing the other STRB with that procedure I should test the "resettet" one on a used C300i.
                        • tsbservice
                          Field tech
                          • 8020
                          I would do it exactly like that.
                          Let us know if it works for you.
                          • Gift
                            • Mar 2011
                            • 2459
                            will do, might take some time though but I've taken my "bad storage board collection" out of the drawer and on to my desk as a reminder
                            • garnerfor
                              • Nov 2022
                              • 2
