Konica Minolta Rebuild Kits
  • Kenny
    • Jun 2009
    • 529
    Hi guys,
    does anyone have a list of parts required to refurb/rebuild the following:
    C224/C284/C364 Fuser
    C454 Fuser
    C554 Fuser
    C458 Fuser
    C558/C658 Fuser
    DR512's
    DR313's
    c224/c658 Transfer belts
    thanks in advance
  • techsxge
    • Jan 2022
    • 660
    Re: Konica Minolta Rebuild Kits
    Originally posted by Kenny
    Hi guys,
    C454 Fuser
    C554 Fuser
    C458 Fuser
    C558/C658 Fuser
    DR512's
    DR313's
    thanks in advance
    If you mean the fusing units of those machines: As far as i know there are no single parts to order. Only whole units.
    As for Transferbelts and Drum Units, i purchase drum cores and transfer belts from cps or other sellers.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Only aftermarket parts are available to rebuild these consumables.
      All the parts to rebuild fusers, drums & transfer belts can be purchased here: Copylite - Aftermarket, Compatible, and OEM Copier Supplies and Products
      I've had good results and saved a lot of money using these parts.
      • Kenny
        • Jun 2009
        • 529
        thanks for this, i will have a look through!
        • Brad6784
          • Mar 2015
          • 78
          I use a UK company - Data Direct for fuser rebuild kits for the C554, C558, C658, C754, believe it or not, it's one kit that fits all. I've been super impressed with the kit, comes with all new bushings, bearings, claws, even cleaner roller bushings, as well as the rollers. I can rebuild them quite quickly now and always keep kits in stock, very happy with them!
          • tulintron
            • Jul 2014
            • 668
            Link?
            • Brad6784
              • Mar 2015
              • 78
              Originally posted by tulintron
              Link?
              Both kits required for a full rebuild, the information on the link shows machine compatibility, I hope this helps!
              Main fuser kit
              Konica Minolta C554 554E Main Fuser Kit
              Sub fuser kit
              Konica Minolta C554 554E Sub Fuser Kit
