c759 CE PASSWORD RESET
  • Kenny
    • Jun 2009
    • 536
    Hi guys,
    does anyone have any suggestions on how to reset the CE password for a konica C759?
    i have tried going to LMS but there isnt an option for me to reset the CE password.
    i have tried to change the HDD and formatted but the usual password doesnt work and no one knows the previous
    calling Konica isnt an option
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: c759 CE PASSWORD RESET
    will this work?
    1. Press and hold the Reset key while powering the MFP ON
    2. When the black dot appears in the upper right hand portion of the screen, release the Reset key
    3. The device is now in the Trouble Reset screen
    4. Select Keypad
    5. Enter Stop 00 Stop 01
    6. If applicable input CE password 9272 4 times (Default) try twice, try 12345678.
    • Kenny
      • Jun 2009
      • 536
      Originally posted by Synthohol
      will this work?
      4. Select Keypad
      unfortunately it hasnt, its driving me crazy haha
      does anyone else have access to LMS that can change CE passwords? i can provide the information
      • emujo2
        • Mar 2017
        • 1579
        Are you a dealer or direct? If so SSD will help you reset the CE password. I know of no other way to bypass this security feature. E
        • Kenny
          • Jun 2009
          • 536
          • techsxge
            • Jan 2022
            • 660
            Do you get them from the KM Support People or over the LMS Website?
            • Kenny
              • Jun 2009
              • 536
              KM Support people
              • Tonerkiller
                • Oct 2012
                • 669
                will this work?
                4. Select Keypad
                I am tryin to delete the customer data from a C759, is this what i need to get into service mode? what do I do from there.
                • Elmo
                  • Feb 2010
                  • 541
                  you don't need to be in service
                  You can erase all data from administrator
                  admin-security-data management or something like that you can select number of passes and even print a report
                  I Used To Live To Fix Things Now i Fix Things To Live
                  • otphas
                    • Aug 2019
                    • 127
                    Did you tried 5624+ last 4 digits from the sernum?
