Biz hub c552ds adf jam
  • mrfuser
    • 1635
  • mrfuser
    • 1635
    Re: Biz hub c552ds adf jam
    Nobody seen this before?
    • femaster
      • May 2011
      • 1525
      Jam "23" is useless. That's meant to give the end user a warm fuzzy feeling, not to help a technician. You won't find those numbers referenced anywhere in any service manual for any machine.
      Jam codes in the ADF start with "66-". I'd advise getting a service manual so you know what those 1's and 0's mean for the state of each sensor. That will go a long way in assisting your troubleshooting of the problem.
      If you haven't already, reboot the copier. Sometimes if a jam sits long enough the machine gets stuck in a jammed state and won't clear, ever after the cause of the jam is cleared. A reboot will reset things back to normal.
      • mrfuser
        • 1635
        • mrfuser
          • 1635
          • mrfuser
            • 1635
