C6000 power on with j3102
  • oommiiddaann
    • Feb 2012
    • 34
    [Jamming] C6000 power on with j3102
    Hi!
    i have km C6000 that indicates jam 3102 Right after power on and i can not clear at all.
    i swapped fuser and whole ADU unit whit conveyance board but cant fix this Fault.
    please help me my machine is Dead.
    many thanks.
  • wjurls
    • Feb 2017
    • 505
    Re: C6000 power on with j3102
    In what order did you change the fuser and ADU assembly? Fuser first, then ADU? I would confirm that no ICP's are blown on the adu driver board and also the printer control board. Check the fuser exit switch status in state confirmation mode 59-03.
    • oommiiddaann
      • Feb 2012
      • 34
      i checked adu board and adu unit and fuser unit on second machine.all of those are ok.
      im not chek printer control board ICPs yet but it should be for that?
      • oommiiddaann
        • Feb 2012
        • 34
        Finally i checked Printer control board and its ok then change the DCPS/2 board and that solve my problem.
        i think in some cases Printer Control Board cant work Properly and shows wrong jam or mulfunction codes because DCPS/2 can not Supply normal voltage.
        Many thanks.
          • 23010
          Congratulations on your success. Thanks for posting back. =^..^=
