Bizhub C224 Online registration and Firmare Update issues
Re: Bizhub C224 Online registration and Firmare Update issues
So it is supported but the app can't connect to it?. If I'm correct the C224 came out in 2013 I think, I don't know how many more versions of android were supported on the original stock V1 firmware. As I said, I will try the pagescope mobile and if that works from my phone then it just means bizhub RA wasn't yet supported by the stock firmware and that would make good bit of sense to me since when did the app originally come out...2020?. Pagescope mobile came out in 2013 so it makes logical sense for me now that only that app is supported, I'm sure the firmware updates added support for Bizhub RA along the way, I will check this stiff out today and if I need all the firmware updates I wil log to the "Firmware Update" Section on the forum.Comment
yeah you will not see those choices on this old box..Remote panel needs the CE password enabled along with SSL and the remote panel sever settings ON..The web address will be
HTTPS://XXX.XXX.XXX.XXX:50443/panel/top.html. This is assuming the non e model supports this feature. I don't have one to look at so I can't verify. EComment
Bizhub RA will not connect if Remote Panel Server is not enabled. EComment
