Bizhub C224 Online registration and Firmare Update issues
  • Jadel Labradoodle251
    • Nov 2022
    • 42
    I'm new to the forum and it seems my other post hasn't been approved or just didn't go through so here I will explain again. Got myself a used C224, it has old firmware, isn't "regsistered" and I can't view any information about it from my pc via the online ip address way. It prints fine from mobile and pc but the mobile app somehow can't pair with the printer. I read something about Tokens before and was wondering where to acquire it and how to hook it up so it will be a "registered" printer and ofcourse where to even find the newest avaliable software for the C224 since the auto update option doesn't exist nor does the "browser". The Kind Lady from who I bought it from said she didn't get any tokens or any li else activating kits so she couldn't help me on that. I plan to set up a print server (from an older pc with W10(64 Bit)) and I would ofcourse like to get the registration and the ip address sorted prior to that if possible.
  • Ziggy
    • Feb 2018
    • 801
    Re: Bizhub C224 Online registration and Firmare Update issues
    I hope you didn't spend to much money on this machine it has been obsolete since Dec.2020. Not sure why you cant reach the machine via the IP address you don't need any kind of token to reach it this way. If you have ever had a printer using the same IP address that this one is now using you could try clearing the cache on the web browser or try using a different web browser. As far as the mobile app make sure you have the latest Konica Minolta mobile app. The latest mobile app is called Konica Minolta mobile print. you don't need any token for any of this to work. You could try updating the firmware to the latest version but if you firmware is real old you need to step firmware up. I would only skip a couple and work my way up to the latest.
    • rrrohan
      • Sep 2011
      • 1977
      are you using HTTPS or HTTP to access PageScope
      chances are it was not configured for SSL web interface
        • Nov 2022
        • 42
        Answering few questions, I tried using Opera Web browser but it doesn't work on mobile either, I will download Chrome and see if it could work on it, I only paid €350 for it and a new set of toners and a waste box, only 52k prints in total, all drums need to be replaced by 2024 or 20255 so that might be costly. What I found funny regarding the mobile app is the fact it only sees it with auto configuration, manual inputting the IP Address gives the "printer not exists". I would prefer to configure it for HTTPS printing if that would be possible at all
        • techsxge
          • Jan 2022
          • 660
          If Serial Number etc are not set you cant access pagescope
          • avecosat
            • Jun 2012
            • 305
            For firmware update you only need a firmware and a USB
            • techsxge
              • Jan 2022
              • 660
              If functions like pagescope are not working, a common fix for the 224e / 284e / 364e is to install new firmware and moviedata.
              Not too sure what you mean by "not registered" but if the machine does not have the serial number put in most stuff will not work (machine will tell you though)
                • Nov 2022
                • 42
                It does have a serial number actually. What I mean by "not registered" is when you connect in mobile it should say "registered" in the lower left corner when you are on the "auto config" section in there. Does the app not prefer unregistered printers and hence why I can't connect it?
                • techsxge
                  • Jan 2022
                  • 660
                  For Mobile Printing i justinstall the app called "Konica Minolta Print Service". Then i add they printer on the app with ip and everything works fine
                    • Nov 2022
                    • 42
                    Well thatw alright then, what about being able to view the info from the web ?, what do I have to do to get this screen(see picture below)
                    • techsxge
                      • Jan 2022
                      • 660
                      Go to Admin Mode on the MFP, make sure that und Network IP, Subnet and DNS is set. I also recall something that you needed to do in security settings but that is nearly out of my head...
                      maybe try to access it with both https://XYZ.XYZ.XYZ.XYZ and https://XXX.XXX.XXX.XXX and chec if there are any out of date certificates installed
                        • Nov 2022
                        • 42
                        maybe try to access it with both XXX Directory: Sex, Porn & XXX Cam Sites Listing and https://XXX.XXX.XXX.XXX and chec if there are any out of date certificates installed
                        What's with the XXX $ex etc?
                        • techsxge
                          • Jan 2022
                          • 660
                          LOL Copytech searched for an URL i forgot to format it
                          Your IP Address...
                          • emujo2
                            • Mar 2017
                            • 1579
                            you would probably be just fine if you could find a Win 2000 or XP box to connect to it..Security features on today's browsers are gonna block these unsecure sites..I would
                            1. Go into service and do a network data clear, and a HDD logical format..This will set everything back to factory including deleting any installed SSL certs (the one you have had probably long past expired)
                            2. Back in Admin and if you are a DHCP environment, pull all fresh info, then set the IP to what you need.
                            3. With SSL removed and antiquated/expired certs gone try logging in with several browsers..Firefox with SSL/TLS requirements set to lowest level, or IE in compatibility mode. Hope this helps. E
                              • Nov 2022
                              • 42
                              I actually just changed the IP address and it worked, suprised myself tbh, its actually now saying on the printer screen "Operating remotely Please do not turn the power off" I was also able to log into admin mode on the remote screen. It asked me to set up SSL for "secure reason" but eh since its a printer thats only being used by myself then I guess it should be alr. I wonder if there will be qn option for the "web browser on the printer itself now.
