Konica Minolta Bizhub 4700p feed rollers for drawer 2
  • copykat93
    • Oct 2021
    • 281
    Hi guys, I looked high & low for bizhub 4700p drawer 2 feed rollers & I can't seem to find them anywhere. It is similar to lexmark, where you pinch the tab on the feed assy. and it slides off the shaft, I want to replace them for my customer , but I cant find them ... Any help appreciated. I looked on eBay, Precision roller & google, no luck
  • tsbservice
    Field tech
    • 8052
    Re: Konica Minolta Bizhub 4700p feed rollers for drawer 2
    Konica Minolta bizhub 4050 Pick Tire Set (2pcs set), Genuine (K4276)
    You can swap only tires. But inform your customers that this is old and outdated model and sooner than later parts may not be obtained.
    • copykat93
      • Oct 2021
      • 281
      Thanks.... but these look like the feed rollers for drawer 1..Green .. Drawer 2 has an assy that you can pull off the shaft & clean them & they are gray in color.. Are you saying that drawer 2 feed assy is not a replaceable item as a unit, and the green feed tire will work for drawer 2??
      • tsbservice
        Field tech
        • 8052
        Honestly I never seen 2 trays on this model but I guess you can easily swap tray 1 and 2 tires as a test The color of rubber really doesn't matter as I have both green and grey.
        • copykat93
          • Oct 2021
          • 281
          I don't mind using the green, I just wanted to be sure that the tire you recommend from Precision Roller will fit my application.
          • tsbservice
            Field tech
            • 8052
            Nope I can't guarantee right now. Will check my parts manuals and come up later with answer.
              • 23010
              is this what you're looking for?:
              Lexmark MS610dn Pick Roller Assembly, Genuine (E2769)
              250 sheet optional tray Konica Minolta PF-P11 is the same as Lexmark 35S0267 (on MS610dn)
              550 sheet optional tray Konica Minolta PF-P12 is the same as Lexmark 35S0567 (on MS610dn)
              • copykat93
                • Oct 2021
                • 281
                Thank you so much!! You guys rock!!
                I love this site!
                • tsbservice
                  Field tech
                  • 8052
                  Yep checked manuals - main machine and optional tray pickup tires/rolls are the same.
