abort bizhub c200
  • giorgio79
    • Nov 2022
    • 2
    abort bizhub c200
    I see this message. bizhub c200
    ABORT
    code =0x0000b016
    tskname =tRT32767
    tskind =0x00007fff
    build_2231.130306
    please wait
    stays on for 30 seconds and turns off.
    by moving the white flexible cable it turns on and off, of the motherboard.
    Has anyone had similar problems?
  • Synthohol
    Certified Konica Expert
    • 5891
    Re: abort bizhub c200
    0x00000000 to 0x000fffff OS processing system failure • MFBUB
    id check all the connections and try firmware first then if no joy replace the board.
    • giorgio79
      • Nov 2022
      • 2
      I thought so too motherboard.
      i have this card code MFBU AF1-00474 AG1-000327-005 LOT- /secondary code 0822-008
      on the internet I found this one that only changes the numbers at the bottom MFBU AF1-00474 AG1-000327-005 LOT- /secondary code 0830-008.
      Do you think it is compatible?
