BH 226i Copy/Scan Overlapping Issue
  • subhashck
    • Mar 2020
    • 18
    [CQ] BH 226i Copy/Scan Overlapping Issue
    It's a new BH226i MFP. Checked the Scanner Harness. Found OK. in Scan/Copy there is Overlapping in the left side. Need help and suggestion. Please find the attached Photographs of the original and copy output. Same thing happens in case of Scan also.
    Subhash Chandra Kalita.
  • techsxge
    • Jan 2022
    • 660
    Re: BH 226i Copy/Scan Overlapping Issue
    Check drum unit and maybe transfer belt
    • subhashck
      • Mar 2020
      • 18
      Thanks for your reply. But the problem occurs in scanning also. Normal print from PC is OK. Counter Print List / Demo Page is OK.
      • subhashck
        • Mar 2020
        • 18
        Please....anyone to provide solution or any hints to resolve the problem.
        • techsxge
          • Jan 2022
          • 660
          clean scanner unit and scanner glass?
            • 23002
            Clearly, it's an image processing error of some sort. I've seen this exact sort of defect on the PRESS 1052, which uses an LED exposure/printhead.
            Most likely, there is not anything mechanically wrong with the scanner, it's the electronic image processing that is creating this fault. =^..^=
            • techsxge
              • Jan 2022
              • 660
              you are right, must be some sort of "software" or eletronic issue. Maybe update firmware?
              • subhashck
                • Mar 2020
                • 18
                Thanks a lot for your valuable input. I'll check and confirm.
                • subhashck
                  • Mar 2020
                  • 18
                  • tsbservice
                    Field tech
                    • 7995
                    Unfortunately this is low end KM B&W A3 lineup.
                    Still POS.
                    • jwai
                      • May 2018
                      • 508
                      Try to replace CIS module
