C224e SSD Replacement
  • Frankrw
    • Nov 2012
    • 12
    [Error Code] C224e SSD Replacement
    Hi all you knowledgeable people hope someone can help when Konica Minolta cant.
    Replaced SSD card on C224e
    Updated firmware to current version and mass firmware
    Updated movie data
    Machine works fine until there is a paper jam. It then goes to error C-D382 restore data
    Let machine run for 5 hours and nothing. If I block any paper sensor machine shows jam
    but when running and jams gives code.
    Any help will be appreciated
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C224e SSD Replacement
    Updated movie data
    checked the battery?
    Any C-D codes on these e series should trigger pulling out the multimeter and checking the battery voltage with the machine power turned off. Dont measure voltage with power turned on, there is minuscule amount of current backfed to the battery with power on and a totally dry battery will still show 3v.
      • 8132
      Updated movie data
      Could possibly be an issue with the HDD since when there is a jam it will display the movie data stored on the HDD.
      Try formatting the HDD or 'unset it'
      • Frankrw
        • Nov 2012
        • 12
        Thanks, tried reformatting HDD, unplugged it, reinstalled firmware same fault when jam occurs
        • Tech Helpdesk
          • Jul 2015
          • 112
          One of our engineers had this today and replaced the NVRAM, updated the firmware and waited for the code and recovered data and all working ok now.
          When testing for the fault he would make the machine jam and the code would appear, disabling the HDD did not help, but when doing a State Confirmation Check / SSD Check the SSD would display NG.
          • tsbservice
            Field tech
            • 7977
            Correct SSD for the model used? Machine type also must mach model.
            • Frankrw
              • Nov 2012
              • 12
              Correct SSD correct Machine and model correct. Ran system check SSD OK hdd OK Nvram OK
              About to throw machine out the door
              • femaster
                • May 2011
                • 1482
                Was this a NEW SSD drive, or one pulled from another machine? If pulled from another machine, what is the firmware version on the SSD? If it's V6.02, then the standard firmware updates won't be able to update it. The SSD Tool (A5C10Y0-F000-G00-A9-04--SSD-FW-Ver6.03m.exe) would need to be run on it to test it and update it to V6.03 before the standard firmware can update it to the latest version. Once updated to V6.03 run the standard firmware to update it to the latest.
                I can't say that this will fix your problem, but there were issues with V6.02 that would actually cause the SSD to go bad.
                • tsbservice
                  Field tech
                  • 7977
                  Interesting. I'm going to PM you.
                  • Frankrw
                    • Nov 2012
                    • 12
                    Is new SSD card. Thanks will try the SSD firmware again
