C654 all data clear for error ....help rectore
  • TEST10
    • Jun 2010
    • 69
    help to restore configuration, some utility options do not appear and no copy windows, no scanner and so on
  • emujo2
    • Mar 2017
    • 1579
    Re: C654 all data clear for error ....help rectore
    I would treat this like a new install and set it up from scratch using the setup guide..You will also need to add the HDD, set the marketing area, and possibly enter the printer S/N.
    • tsbservice
      Field tech
      • 8081
      What have you done it prior?
      • TEST10
        • Jun 2010
        • 69
        I have already achieved a large part ... now I can't print, the IP is fine, it must be the interface
        • Ziggy
          • Feb 2018
          • 815
          have you turned back on the HDD in service mode?
