C257i jams when FS-533 fitted
  • Luka
    • Dec 2022
    • 11
    Hi,
    I have a c257i jamming on double sided when fs533 is fitted.
    Any ideas pls?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: C257i jams when FS-533 fitted
    thats pretty vague, got a jam code by chance?
    • Luka
      • Dec 2022
      • 11
      3205
      It just looks like the paper hits the finisher when exiting the body just before going back in for the second side
        • 23009
        Make sure that the exit rollers are turning easily. You'll get these symptoms when the machine exit rollers seize.
        What happens when you set the media type to heavy? Does it feed? =^..^=
        • Luka
          • Dec 2022
          • 11
          It works perfectly fine without the finisher
          I am just wondering if it needs another additional unit installed to make it work with the main body
            • 23009
            No, but it does need the exit rollers to be able to turn. =^..^=
            • Luka
              • Dec 2022
              • 11
              Exit rollers are fine.
              just strange that there is only one exit so there is no duplex exit for double sided...
              • B0265
                • Jan 2007
                • 718
                I think you have missed to install the MK-603.
                • suomi
                  • Oct 2008
                  • 152
                  & MK-602
                  • Luka
                    • Dec 2022
                    • 11
                    Hmm I have installed mk602 but didn't know it needs mk603 as well.
                    Will try that thanks
