BH450i Not Powering ON
  • subhashck
    • Mar 2020
    • 18
    [Dead] BH450i Not Powering ON
    Hi everyone!
    Earlier the MFP BH450i was having Paper Jam issue at the Paper Registration Sensor. So, cleaned the Paper Registration Sensor and refitted it. Switched ON the machine, but no response! Properly checked all the Harnesses & Connectors. But same issue. Tick sound comes from the DC Power Supply while switching ON.
    Finally, when I disconnected the CN7 of the DC Power Supply which is connected to the CN2E of the BASE Board, the MFP starts initializing. But Trouble Code E-6756 and Error Code E6-1 comes after some time.
    So, I need your valuable feedback & tricks to resolve the issue and its Root Cause.
    Photos are attached herewith.
  • Synthohol
    Certified Konica Expert
    • 5848
    Re: BH450i Not Powering ON
    last time i had anything even close it was the CPU board and i replaced the storage board at same time.
    • tsbservice
      Field tech
      • 8020
      Originally posted by subhashck
      Hi everyone!
      I'm not saying that is the root cause but those i series must be serviced unplugged from wall outlet otherwise they keep some voltages even power switch off. Maybe try another base board.
      • trscolin
        • Aug 2012
        • 21
        Error
        C6756 at power on and scanner light working fine.
        Root Cause
        New CCD/CIS installed without updating firmware
        Workaround/Fix
        Install firmware based on models outlined in attached bulletin 12525.
        C450i/C360i/C300i/C250i/C750i/C650i/C550i/450i/360i/300i/750i/650i/550i✔ - G00-G4 or later
        • subhashck
          • Mar 2020
          • 18
          Thanks for your feedback.
          It powers ON when the CN7 of DC Power Supply is disconnected which is connected to CN2E of BASEB.
          Wiring Diagram attached. Any clue from the Diagram?
          • Gift
            • Mar 2011
            • 2459
            What happened if you leave CN7 connected but disconnet other conenctors/harnesses from base board step by step.
            • tmmdmmm
              • Apr 2021
              • 173
              Pinched/Cut wire to the registration unit? Only time I've heard a click and black has been a short to ground. Unplugging power to the Front board like you did would get rid of that short. Plug the front board back in and unplug the connectors from the front board to registration.
              Once you have the front board powered but the registration unplugged see if it boots. Ideally it does, with a "jam" from the reg sensor or a different error related to the reg. You can also try booting with the doors open. That stops a lot of activity to the boards, so you might fully boot up but once the doors close it shorts and powers down.
              • subhashck
                • Mar 2020
                • 18
                Thanks for the trick. Will check and update.
                • tech51
                  • 846
                  Had this in a school that had been nuked by the power company ( apparently they connected the wrong phases up after repairs and ended up frying an entire village)!
                  It did exactly what you describe in that I could pull off connectors and it would part boot, then error.
                  That one turned out to be the power supply board.
                  This was a C360i btw.
                  Might be worth taking one with you.
                  • subhashck
                    • Mar 2020
                    • 18
                    Replaced the BASEB, CPUB and DC Power Supply. But problem not resolved. Any idea?
                    Thanks in advance!
                    • Gift
                      • Mar 2011
                      • 2459
                      Thanks in advance!
                      did you follow tmmmtmmm's suggestions?
                      • subhashck
                        • Mar 2020
                        • 18
                        Yes. I followed his tricks. But same issue!
                        • tsbservice
                          Field tech
                          • 8020
                          Did you try another FSB(front side board)?
                          • subhashck
                            • Mar 2020
                            • 18
                            There is no FSB in this model I. e. BH450i
                            There is EXCB at rear side above BASEB.
                            Till now found no connector cut!
                            • subhashck
                              • Mar 2020
                              • 18
                              If the CN7 connector of the DC Power Supply Or the CN2E connector of BASEB is disconnected (the same connector connects the BASEB and the DC Power Supply) the machine boots but no Copy/Scan or Print function!
                              Wiring diagram attached. Can anyone explain the Operation Or Signal/ Boot cycle of the Connection?
