CD341
  • romario
    • Jun 2020
    • 196
    [Error Code] CD341
    C308. Can someone help me with the error D341. the machine when printing from pc. It gives an error, it restarts 1 time and comes out ready to print again. I see the internal errors and it shows D341. update fw latest version and follow the error. the machine won't let me do the data recovery
    thanks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4828
    Re: CD341
    CD341 nonvolatile data error
    Root Cause
    1. Poor connection on MFPB or data corruption
    2. Corrupt Hard Drive (HDD) data.
    3. Corrupt EMMC data
    Workaround/Fix
    1. Perform the steps outlined below.
    a. Reseat all connectors on MFPB
    b. Reseat HDD, EMMCB and DSIPB
    c. If the above does not resolve the issue enter Service Mode -> Utility -> Counter -> Stop 00 -> Stop 01
    d. Press the following keys in this order
    • Stop -> 2 -> 9 -> 8 -> 2
    • Touch Clear [NVRAM Clear]
    Notes:
    e. This clears the Nonvolatile memory information
    f. Machine will automatically reboot when completed
    2. Perform a Physical and Logical format of the HDD.
    a Select Counter
    b. Select Display Keypad
    c Press Stop 00 Stop 01
    d. If applicable input CE password 9272 4 times (default)
    e. Press End to enter Service Mode
    f. Select State Confirmation
    g. Select Memory/Storage Adjustment
    h. Select Format
    i. Select Physical Format
    j. Press the Start key
    k. Once completed, power OFF MFP for at least 10 seconds and reboot
    l. Repeat Steps 1 through 4 to enter Format area again
    m. Select Logical Format this time
    n. Press the Start key
    o. Once completed, power OFF MFP for at least 10 seconds and reboot
    3. Format EMMC by performing the following.
    a. Press Counter
    c. Press Stop 00 Stop 01
    d. If applicable input the CE password 9272 4 times (Default)
    e. Press END
    f. Select System 2
    g. Select HDD
    h. Select Uninstall HDD
    i. Reboot the machine.
    j. Enter Service Mode
    k. Select State Confirmation
    l. Select Memory Storage Adjustment
    m. Use the > key and go to page 2 of 3
    n. Select Format
    o. Select Physical
    p. Once the OK appears in the display, reboot the machine
    q. Repeat steps 6 -8
    r. Select Logical
    s. Select Start
    t. Once the OK appears in the display, reboot the machine
    • avecosat
      • Jun 2012
      • 305
      Re: CD341
      Hello, I have the same code but when I touch the sequence stop-2-9-8-2, "touch clear" does not appear. I don't know what I'm not doing right. Thank you.
      • Synthohol
        Certified Konica Expert
        • 5961
        Re: CD341
        dont type the 9272... just the listed sequence.
        • tsbservice
          Field tech
          • 8109
          Re: CD341
          Search for "Nonvolatile memory" in C250i service manual it's there for sure.
          • avecosat
            • Jun 2012
            • 305
            Re: CD341
            I solved it with a recovery data, thanks
