bizhub c224e - change of default settings - external memory
  • KARR
    • Jan 2023
    • 1
    Hi all.
    I'm starting to be crazy about how to change default settings for bizhub c224e when I'm scanning (saving) files to external memory.
    For example I wanna make 300 DPI as my default setting.
    I've checked how to do it for scan but I can't find anywhere for external memory.
    Thank you very much.
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: bizhub c224e - change of default settings - external memory
    scan to USB is usually the least used function so the ability to change usb scanning default DPI does not seem to be a thingas far as i can see.
    its such an on-the-fly operation i dont think much thought was given to having the ability to set a default for that other than the standard 200x200
    • emujo2
      • Mar 2017
      • 1579
      Synth is correct..I tested e series through I series, any changes to the default scan settings are overridden when scanning to USB..I searched manuals and tech support sites, I can find nothing that allows you to hold these settings. Though maybe scan to user box, then scan to USB, but that's not an option either. Good to know. E
