Konica Minolta C6100 printing issue big white space in middle
  • reckless
    • Feb 2017
    • 188
    What does this indicate having these streaks in middle? Its also got tiny streaks everywhere.
    WhatsApp Image 2023-01-05 at 3.50.34 PM.jpgWhatsApp Image 2023-01-05 at 3.50.33 PM.jpg
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 170
    Re: Konica Minolta C6100 printing issue big white space in middle
    Please print a halftone for each color for more diagnosis.
    Sent from my CPH2239 using Tapatalk
    • reckless
      • Feb 2017
      • 188
      So I printed an 8.5x11 and it printed fine. But when printing larger 12x18 paper 350gsm its giving that problem. How do I print halftone of each color?
      • reckless
        • Feb 2017
        • 188
        We printed the test page from printer and it came out perfect.
        Recently about a week ago I updated fiery, we usually print stored jobs using much older fiery software. Could that cause the issue?
        • reckless
          • Feb 2017
          • 188
          Letter size test pages coming out perfect:
          WhatsApp Image 2023-01-09 at 5.38.21 PM.jpgWhatsApp Image 2023-01-09 at 5.39.40 PM.jpg
          12x18 coming out like crap:
          Can this be related to Adobe? We are using Illustrator and Acrobat
          • Ziggy
            • Feb 2018
            • 710
            To print a sample of each color go into service mode > test print > print test target 43. print it in full color and on 12x18. this will let you know which color is having truble
            • tulintron
              • Jul 2014
              • 668
              [ATTACH=CONFIG]56196[/ATTACH][ATTACH=CONFIG]56195[/ATTACH]
              I believe that this transfer failure has to do with the condition that the paper is in. It tests the same format with other types of paper, other weights.
              • reckless
                • Feb 2017
                • 188
                We checked paper in an OKI color laser printer and its printing fine. So I dont think its paper. I printed test on thick stock:
                Also printed from other paper trays and got this on regular stock??
                Not sure what is going on?
                • reckless
                  • Feb 2017
                  • 188
                  So the problem keeps migrating. See today's prints.
                  WhatsApp Image 2023-01-12 at 5.34.06 PM.jpgWhatsApp Image 2023-01-12 at 5.37.01 PM.jpg
                  • Ziggy
                    • Feb 2018
                    • 710
                    [ATTACH=CONFIG]56280[/ATTACH]
                    [ATTACH=CONFIG]56281[/ATTACH]
                    With it being all colors I would suspect its something in the 2nd transfer assembly. You could run a test target 53 with black at 255 density and all other colors set at 0 density. then print black only and stop machine before it completes 2nd transfer and see what image looks like on transfer belt. If it looks good and solid black on transfer belt then you would know for sure that you have a 2nd transfer problem
                    • reckless
                      • Feb 2017
                      • 188
                      So we figured out what the problem is, we changed the speed of the paper to slow and it started printing without the line. But we are still having a problem that it is tearing/ripping the paper. See below. How do I fix?
                      • shettyprakash.thane
                        • Jan 2023
                        • 2
                        Hi,
                        Have faced the same issue on c6085 machine. The bands (Transfer failure ) was found to be of the 2nd Transfer unit. To improve transferability to media KM has modified the width of the Transfer roller and the Transfer Collar in the 2nd Transfer unit..
                        Current Parts No.
                        New Parts No.
                        Parts Name
                        A92WR70700
                        A92WR70722
                        2nd Transfer Unit
                        Hope it resolves your issue. Thanks.
                        • reckless
                          • Feb 2017
                          • 188
                          THANK YOU!!! Do you think the old part can cause paper jamming as well for thick paper stock 350gsm?
                          I get surprised how KM operates with these issues in the field. $533 for new transfer unit for their poorly designed unit which did not last 1000 copies.
                            • Jan 2023
                            • 2
                            Hi,
                            Have you checked the results after replacing with the new Transfer belt unit?
                            Yes we have faced intermediate paper jamming on all media stock above 200 gsm resulting in error code C-2720 on the old Tansfer belt unit. Still NOT faced this issue after installing the new modified 2nd Transfer belt unit.
                            Thanks.
                              • Mar 2012
                              • 170
                              Did you tried to swap the I.T.B unit to be sure that is accuse the issue.
