Develop ineo 758 J9310 duplex jam
  • nfw
    • Sep 2022
    • 3
    Hi, I have a Develop (badged Konica) ineo 758 with close to 800k suffering from intermittent J9310. C2151 has also appeared a number of times at point of jam. I have replaced the 2nd transfer motor to fault find- there has been no error in 4000 prints but 5x J9310. Upgraded to the latest mass-production firmware (G00-W5), cleaned and swapped a few sensors in the ADU.
    Both codes are related to the paper feed/ paper transport board. Any thoughts?
    I have been to the machine this morning and it is working fine on arrival.
    Thanks,
  • kingarthur
    • 1385
    Re: Develop ineo 758 J9310 duplex jam
    You've had 5 misfeeds in 4000 prints - i'd say that's working....
      • 23010
      Let me clarify a few things:
      Did you run at least 200 duplex without jamming?
      And it has done 4000 duplex images since then?
      It could very well have been a paper curl issue that was resolved by using up that paper. You don't really have anything to fix.
      If you can get it to jam, take a look at paper sensor PS48 flag. If your customer runs 100% duplex ... every single page duplex, that flag will start so show wear/flattening after ~1M pages. =^..^=
      • nfw
        • Sep 2022
        • 3
        I ran around 100 duplex with no jam.
        The machine had done 4000 prints between calls with 5x J9310 recorded in that time.
        It is in a school common room so it gets used quite heavily- averaging around 30,000 prints a month. It has been ongoing for a while so doubt its the paper.
