Fiery E100-02 IC-413 For KM Bizhub Press C7000P
  • Synthohol
    Certified Konica Expert
    • 5868
    #16
    Re: Fiery E100-02 IC-413 For KM Bizhub Press C7000P
    also the fiery ip will likely be 172.254.x.x to start. command workstation should find it then run the fiery setup from CWS and input all your settings.
    • Danny9279
      • Feb 2022
      • 15
      #17
      Thanks Synthohol,
      Your solution worked, I was able to install the fiery ISO vie the network connection. What threw me off was that I assigned a 10.10.10.1 as the IP but apparently the Fiery Network Card had an embedded IP of 192.168.x.x
      This morning I was able to connect via the Workstation. This afternoon I'll work on it to get it finalized.
      But again Thank You Very Much for the Assist.
      • Synthohol
        • 5868
        #18
        anytime.
        • tsbservice
          Field tech
          • 8031
          #19
          Originally posted by Danny9279
          Thanks Synthohol,
          We all like helpful techs being around.
          They are always up to the task 🙂
          Thanks for recognising one of them.
