Copy Animation Data from one C654e to another?
  • RCP
    • Nov 2022
    • 5
    I have two KM Bizhub C654e copiers. One of them is missing the animation data. Is there any way to copy it from the other machine? I have plenty of USB flash drives.
    I know how to install it once I have the file on the USB drive.
    Thanks.
  • emujo2
    • Mar 2017
    • 1579
    Re: Copy Animation Data from one C654e to another?
    Nope..not possible. E
    • otphas
      • Aug 2019
      • 119
      I never think about it, because i have movie data files, but you try to clone the HDD!
      • davidmtupper
        • Jul 2021
        • 326
        Nope, putting the cloned drive in the machine that needs the movie file will cause it to be formatted, different serial number among other issues.
        • tsbservice
          Field tech
          • 8020
          Thanks.
          Contribute few bucks to this site and someone will provide it to U.
          • RCP
            • Nov 2022
            • 5
            Thanks for the input. I figured it probably wasn't possible because the only options shown are for installing data.
            This machine has been running without the animation data for a while without any real issues. I guess it will continue that way.
              • 23009
              The movie data on the HDD is encrypted, and there is not a way to export it AFAIK. The encryption password on the other machine will be different ... not usable on the first machine until the HDD is formatted, encryption passphase assigned, and movie data re-loaded in that order. =^..^=
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                You are correct that you can continue to use machine the way it is. But not sure why you think a small "one time" donation like $5 or $10 to support this website isn't worth it. Not only for the animation firmware but in the future for other tech support, manuals, etc. Once you have that red "Contributor" badge under your name it goes a long way. Just saying.....
                • RCP
                  • Nov 2022
                  • 5
                  Just to clarify... This was an unfortunate situation of poor timing. My response was being composed before the suggestion for contribution had been made. I was replying to all the earlier responses. I am not opposed to the idea of supporting the site.
