KONICA MINOLTA C360 model magenta stains
  • Termi
    • Aug 2022
    • 12
    tcr level for magenta went to 3.29% so i was getting code 2553 . So i manually added toner by going in service menu then my copies are like this . Can anyone help me with this please.sample pdf_Page_1.jpgsample pdf_Page_3.jpg
  • Gift
    • Mar 2011
    • 2459
    Re: KONICA MINOLTA C360 model magenta stains
    If you cross-swap magenta and cyan drum, does this problem persist?
    • Termi
      • Aug 2022
      • 12
      changed the drum once but same thing happening.
      • Mitch Barron
        • Mar 2013
        • 180
        Check developer, once happened that to me I was just changing Drums but it was not that but the Developer.
        • Termi
          • Aug 2022
          • 12
          as you said i swapped magenta and cyan drum but problem persist. anyother thing i can do?? plz help
          • copier tech
            • 8131
            Originally posted by Termi
            tcr level for magenta went to 3.29% so i was getting code 2553 . So i manually added toner by going in service menu then my copies are like this . Can anyone help me with this please.[ATTACH=CONFIG]56342[/ATTACH][ATTACH=CONFIG]56343[/ATTACH]
            Are you using genuine Konica Minolta toner ?
            • Termi
              • Aug 2022
              • 12
              yes purely genuine bcoz i had suffered a lot in my old machine due to aftermarket toner
