Bizhub Pro 1100 please wait starting system
  • Naveed Shahid
    • May 2008
    • 162
    [Misc] Bizhub Pro 1100 please wait starting system
    Hello Every One ,
    please wait starting system stuck screen Bizhub 1100 pro.
    machine not Booting Its Look May Be Issue In NV ram ? any procedure to recover NV ram or initialization .
    Any Advise Plz
    Thanks & Regards
  • Ziggy
    • Feb 2018
    • 687
    Re: Bizhub Pro 1100 please wait starting system
    Originally posted by Naveed Shahid
    Hello Every One ,
    Any Advise Plz
    Thanks & Regards
    Found the following
    Problem
    Unable to complete firmware update. After machine reboot "Please wait, initializing hard drive" message appears.
    Solution
    CAUSE: Possible interference occurs with HDD connected.
    SOLUTION: Install firmware with HDD disconnected following this procedure
    1. Power OFF the machine
    2. Disconnect the 2 cables on the Overall Control Board (OACB) that connect the HDD to the machine
    3. Boot directly into Service Mode
    a. Hold the Utility button while powering ON the machine
    4. Reflash the firmware
    5. After firmware is completed the machine will reboot
    6. Power OFF the machine and reconnect the HDD
    7. Power ON the machine.
    Problem
    PROBLEM: Constant "Machine Warming Up" on the display.
    No error codes are displayed, fuser lamps come on and cycle after a few minutes to maintain temperature but message wont clear
    Solution
    CAUSE: ADU release handle or Sensor not showing the ADU as closed and locked
    SOLUTION: Check the following items and replace if necessary:
    1. ADU handle release sensor PS44 P/N(9335150021)
    2. Carriage Pulling Lever P/N(56UA46921)
    3. Release jam label P/N(A0G6945400)
    4. Lever lock Claw P/N(55VA49240)
    5. Lever locking SD6 pin assy P/N(A4EUR73V00)
    hope this helps
    • Naveed Shahid
      • May 2008
      • 162
      Originally posted by Markks
      Found the following
      Problem
      Solution
      Problem
      Solution
      hope this helps
      Thanks For Replay I done All Above Steps But Result Remain Same .WhatsApp Image 2023-01-20 at 16.45.11.jpg
      Boot directly into Service Mode but problem remain same
      Now I cannot flash firmware until machine boot right ?
      any advice
      • Ziggy
        • Feb 2018
        • 687
        Thanks For Replay I done All Above Steps But Result Remain Same .[ATTACH=CONFIG]56413[/ATTACH]
        any advice
        If it wont even boot into service mode you may have a printer control board problem.
        • Naveed Shahid
          • May 2008
          • 162
          Its Look Like Issue in Nvram As per My Calculation
          Thers is special firmware Mass Production firmware Ver30 DLBT1616975EN i m looking to get that one
          One other way is if i get ISWTrns_G software Its will help to resolve problem
