C250i Yellow Image Missing
  • gra1
    • Oct 2012
    • 8
    Hi
    Having a issue with a C250i with yellow missing from prints and copies FW is latest GC2-N4 TCR Values are all correct and within the Ranges and do go up and down when test pages are printed Checked Developer and Drum Developer is getting Yellow Toner.
    Have attached Demo Page for Example.
    I am Thinking that it might be the HV Board but not sure
    Many Thanks for any help
  • tsbservice
    Field tech
    • 8019
    Re: C250i Yellow Image Missing
    Originally posted by gra1
    Hi
    Brand new machine?
    • gra1
      • Oct 2012
      • 8
      Brand new machine?
      No only done 5k in total
        • 23008
        Did you emergency stop the machine to determine if there is a yellow developed image on the primary transfer belt? =^..^=
        • gra1
          • Oct 2012
          • 8
          Yeah no yellow on Transfer belt also Gradation Pages CMYK no yellow is on belt or on the test pages.
            • 23008
            Was there any yellow on the developing roller, or was it gray (developer only)? =^..^=
            • gra1
              • Oct 2012
              • 8
              Checked Developer roller and plenty of yellow showing on the roller not not grainy.
              • tsbservice
                Field tech
                • 8019
                Check carefully ribbon cable to PH unit. Had one damaged from the factory.
                • larweedad
                  • 92
                  Or first transfer roller on the belt. Does it move, is it broken and not able to touch the yellow drum?
                  • jwai
                    • May 2018
                    • 508
                    same issue on one C224e, repaired connect pins of that cable and fixed.
                    • kopasz
                      • Feb 2018
                      • 7
                      Hello there !
                      We are having the same problem with a C250i , which only done 2k so far .
                      The yellow is totally missing even after the drum , developer, transfer belt and the HV-panel replaced .
                      I got some hint from Konica Minolta to change the Laser unit which will happen next week .
                      I ll update u with the result
                      • gra1
                        • Oct 2012
                        • 8
                        Originally posted by kopasz
                        Hello there !
                        Yes have tried the HV Unint aswell but made no difference still no yellow
                        Are you getting the P- Code for Yellow Drum & Dev Error aswell ?
                        Have also got a Laser Unit on ordered as advised this maybe the issue will update once fitted to see if it fixes or if you get your one fixed before I do would be curious to know if it does fix the fault.
                        • tsbservice
                          Field tech
                          • 8019
                          Check the ribbon cable to the laser unit, we've got one damaged from factory and one of colors missing totally.
                          • gra1
                            • Oct 2012
                            • 8
                            All been checked ribbon cables all OK been reseated and checked no issue with pins or any damage
                            • SimoneCariz
                              • Jan 2018
                              • 7
                              Happened to me too, replaced laser group!
