Bizhub C250i with malfunction code P-14
  • tsbservice
    Field tech
    • 8031
    New machine out of box shows P-14(skew correction trouble). Drums, belt visually checked looking good.
    Think I will go back with some parts but firstly do print head skew reset but any other ideas are welcome.
  • Gift
    • Mar 2011
    • 2459
    Re: Bizhub C250i with malfunction code P-14
    skew reset sounds OK - if that doesnt help: perhaps an adjustable mirror in the laser unit got stuck or has been moved out of range.
    You might also inspect the entire machine very thoroughly - this might be a sign of rough handling during shipping/transportation.
    • Ziggy
      • Feb 2018
      • 789
      I would inspect laser unit and make sure its mounted correctly. It might have been put in wrong or knocked out of place in transit
      • tsbservice
        Field tech
        • 8031
        Went back did some things at the end it was PH unit. Put new PH unit did print head skew reset followed by Initialize plus Image stabilization - problem solved.
