Re: Accuriopress C4070 - IC-609-Connection issue(controller unconnected)
wait, i think there is a bit switch or something to re-enable the hdd after a format or something.
lemme look.
Problem
Unable to print or controller not recognized with the IC-610/IC609/IC-607 after formatting the HDD.
Solution
CAUSE: Version mismatch between Controller firmware (P) and Engine firmware (C,I,W)
SOLUTION: Downgrade "Engine" firmware (C,I,W) to the matching older version of "Controller" firmware (P) then upgrade firmware following either upgrade method below:
1. Use "Package ISW" to apply the latest version of "Controller" (P) and "Engine" (C,I,W) firmware at the same time.
2. Use "USB Memory ISW" to individually update "Controller" (P) and "Engine" (C,I,W) firmware. (Order of firmware install does not matter)
Note: Be sure to update each firmware to the latest level before rebooting machine.
lemme look.
Problem
Solution
