C3320i latest firmware - machine stuck on boot up
  • Brad6784
    • Mar 2015
    • 69
    Hi all,
    I wondered if I could possibly trouble someone for the latest KM C3320i firmware please, I have one stuck on boot up which I hoping the firmware will cure.
    Any help would be very much appreciated.
    Thanks very much.
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: C3320i latest firmware - machine stuck on boot up
    pm sent, give it 5 minutes to finish transferring before downloading.
    • Brad6784
      • Mar 2015
      • 69
      Thank you so much, much appreciated!
      • tsbservice
        Field tech
        • 7975
        May be bad SD card.
        • Brad6784
          • Mar 2015
          • 69
          Thank you, you were right with SD Card, reseated and all is working well! Thanks again
          • tsbservice
            Field tech
            • 7975
            Well what a good timing ☺️
            We're glad you solved it without too much hassle 😃
