C360i Firmware update fail machine stuck on boot up
  • Campus9684
    • Jan 2023
    • 6
    My boss tried updating our Bizhub C360i and after about 30 min he restarted the printer thinking it either completed or didn't start. Turns out it was still installing.
    1. Can I just reflash the latest firmware?
    2. How do I get the latest firmware?
    3. Any other steps you would recommend.
    I spent a few hours going through historical posts so thank you to everyone who is part of this community. These machines are complicated and hidden behind business practices so seeing sites like this exist make me happy.
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: C360i Firmware update fail machine stuck on boot up
    PM sent
    thanks for contributing!
    • Campus9684
      • Jan 2023
      • 6
      @Synthohol No, thank you! 2,500+ Posts is impressive!
      • Synthohol
        • 5847
        well, more like 4000.
        lots of opportunities for folks to know i ride the short bus
        • tsbservice
          Field tech
          • 8020
          Who cares as long as you ride the RIGHT bus 😂
          • rrrohan
            • Sep 2011
            • 1977
            id wait 30 mins before giving up on the original c360 but the c360i im shocked if it takes more than 5 minutes to update
            • Campus9684
              • Jan 2023
              • 6
              Well it turns out we have a C360 not a C360i. Do you have anything for that model?
              I spoke to the boss and it turns out it wasn't a firmware update but he disabled User Authentication and now the errors shows up as C-C211 authentication.
              • tsbservice
                Field tech
                • 8020
                Try to do logical format of HDD(you will lost some data but not a big deal).
                • copier tech
                  • 8172
                  Try this:
                  Description: CC211 error code at power ON.
                  Solution:
                  PROBABLE CAUSES:
                  1.
                  Corrupt data on hard drive.
                  Perform the logical format of the Hard disk assembly using these steps.
                  a. Enter Service Mode: Stop 0 0 Stop 0 Clear.
                  b. Touch these keys in this order: [State Confirmation] g [Memory / HDD Adj.] g Memory/HDD Adj.-HDD Format.
                  c. Select Logical Format (only when initially setting up).
                  d. Touch [Logical Format].
                  e. Press the Start key to start the formatting sequence. The sequence will terminate automatically when it is completed.
                  f. Turn the main power switch OFF; after 10 seconds or more, turn it back ON.
                  IMPORTANT: Formatting the hard disk will erase all data contained on it.
                  • Campus9684
                    • Jan 2023
                    • 6
                    Try this:
                    Solution:
                    PROBABLE CAUSES:
                    1.
                    When I type in the Stop 0 0 Stop 0 Clear it just beeps for each press and nothing happens.
                    • tsbservice
                      Field tech
                      • 8020
                      C'mon dude, watch some YouTube video
                      • Synthohol
                        • 5847
                        stop 0 0 stop 0 1?
                        • Campus9684
                          • Jan 2023
                          • 6
                          YouTube is my go to but I think this model is too old. I did get to the Trouble Reset page hold Utility/Counter until Logo, then type Stop 0 0 Stop 0 1 but the keyboard pop's up for about 1 sec and disappears so I cannot type in the code in.
                          I am reviewing the correct service manual now and will post an update once I have success or more failure. Fingers crossed for the former.
                          • Campus9684
                            • Jan 2023
                            • 6
                            It is fixed! Thanks to everyone for their help.
                            1. I removed the panels and unplugged the hard drive, rebooted.
                            2. Jumped into service mode, selected HDD and changed it to installed (does it reset to not installed?), rebooted.
                            3. Error comes up about HDD integrity, realize I had the hard drive still unplugged so plugged it back in and rebooted.
                            All errors gone. Everything works. Thanks for teaching me a lot!
