Problem with charge in Minolta C454
  • andrecopfac
    • Feb 2020
    • 17
    [Electrical] Problem with charge in Minolta C454
    I'm having problems with extreme background in all prints, I've already changed the drum, developing box and image belt, without success.
    When I add automatic toner in black, it raises the TCR to 6.5 but then drops to 0.30.
    Imagem do WhatsApp de 2023-02-03 à(s) 13.40.04.jpg222.jpgImagem do WhatsApp de 2023-02-03 à(s) 13.40.042.jpg
  • Konicatech
    • Feb 2016
    • 131
    Re: Problem with charge in Minolta C454
    Have seen it before with compatible toners, are you using them?
    If so take the toners out, run halftones until the hopper is empty, then put OEM toner in and run 50 of each CMYK halftone to flush the dev unit through with fresh toner and see if it clears up.
    for the low tcr you will need to likely change the dev unit.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4624
      Are you using new genuine drums & developer units? And like other poster said aftermarket toner can cause this. Keep in mind any over life consumable can cause developer loss in any other color.
      • andrecopfac
        • Feb 2020
        • 17
        We use toner from Minolta C6000 c7000 OK?
        • andrecopfac
          • Feb 2020
          • 17
          • femaster
            • May 2011
            • 1482
            The ingredients between the 2 are different. For starters, the C6000/C7000 toner does not contain the necessary developer mixed with it that the 4-series machines need to keep the development unit properly replenished. There is also a mismatch in the amount of Styrene acrylic resin, which I'm sure isn't helping your situation either.
            Product Name: TONER TN512K (C454)
            3. COMPOSITION / INFORMATION ON INGREDIENTS
            Major Ingredients:
            [Generic Name] [CAS No.] [%]
            Styrene acrylic resin 65-75
            Ferrite:
            - Iron oxide 1309-37-1 1-10
            - Manganese oxide 1344-43-0 1-10
            Wax 1-10
            Carbon black 1333-86-4 1-10
            Wax-2 1-10
            Amorphous silica 7631-86-9 1-10
            Titanium dioxide 13463-67-7 <1
            Product Name: TONER TN616K (C6000)
            Major Ingredients:
            Styrene acrylic resin 75-85
            Wax 1-10
            Wax-2 1-10
            Titanium dioxide 13463-67-7 < 1
            • copyman
              Owner / Technician
              • Sep 2005
              • 4624
              Think you answered your own question. There is no longer a Kon/Min toner shortage so no need to improvise using toners from other models. Even aftermarket toner for correct model gives you a better chance of good print quality then toner designed for a different model.
              • tecnomarco
                • Jul 2011
                • 213
                I also had problems with the tcr that went to zero i had to replace the black toner power motor so 'i solved i hope you are useful this suggestion
                • L0rdC
                  • Feb 2021
                  • 82
                  check the waste toner tank, it should be full of developer
