CE Locked password
  • ltdiniz
    Supervisor de Campo
    • Mar 2021
    • 98
    CE Locked password
  • cube10025@gmail.com
    • Aug 2022
    • 55
    Re: CE Locked password
    Try 12345678
    Otherwise go in to service mode and run initialization, note need to reinstall movie data and APDF
    • Synthohol
      Certified Konica Expert
      • 5823
      Originally posted by cube10025@gmail.com
      Try 12345678
      Otherwise go in to service mode...
      thats the whole issue, the passwords to GET in service mode are unknown.
      • Brad6784
        • Mar 2015
        • 77
        Exactly, reset tool should clear this PW and reset back to standard.
        • ltdiniz
          Supervisor de Campo
          • Mar 2021
          • 98
          ​And as Synthohol said in the post below and the EC password of the unknown Tech mode that some son of God put in the default or even evil.
          • ltdiniz
            Supervisor de Campo
            • Mar 2021
            • 98
            I understand the procedure mate!
            I already did the procedure, but the BH458 equipment does not accept a reset tool.
            That's why I'm looking for the reset code in the LMS.
            • Brad6784
              • Mar 2015
              • 77
              • JasonSBE
                • Apr 2014
                • 184
                If you aren't able to get a reset tool, the only other way that I know of to get access to service mode without the password is to put a ticket in with Konica Minolta. There is a recovery process that involves pulling up a recovery screen and sending a picture of it to their tech support. They then generate a code that you have to input to reset the password.
                • ltdiniz
                  Supervisor de Campo
                  • Mar 2021
                  • 98
                  Colleague, I understood how this process works, but the thing is that this machine came from imports and was not purchased by the local KM, I think I won't be able to open a ticket at KM and that's why I posted it here on the Forum. But thanks a lot for the tip.
                  Enviado de meu Redmi Note 9 Pro usando o Tapatalk
                  • JasonSBE
                    • Apr 2014
                    • 184
                    I'm not sure if anyone here will be able to generate that code for you, but for what it is worth, I have had to put in a ticket with KM on a machine that was not purchased directly from them for this same issue before and they still reset the password for me.
                    • ltdiniz
                      Supervisor de Campo
                      • Mar 2021
                      • 98
                      And it's true I'm going to have to make this ticket at KM via request and hope to receive this CE admin password reset code. I already imagined that it would be difficult to have someone do this here on copytechnet, but thank you very much for the tip JasonSBE.
                      • techsxge
                        • Jan 2022
                        • 660
                        A145FW.TAR does not work on that series? I recall that i've done it multiple times in the past although i can mix it up as we're mainly doing olivetti machines which have slightly shifted model numbers
                        • tsbservice
                          Field tech
                          • 8010
                          @ltdiniz
                          Which reset file you've tried?
                          • ltdiniz
                            Supervisor de Campo
                            • Mar 2021
                            • 98
                            This .tar file ai and the templates from lines 4 and 4e.
                            • ltdiniz
                              Supervisor de Campo
                              • Mar 2021
                              • 98
                              Hello @tsbservice the file I tried to reset was a789...
                              But the equipment did not read the initialization date, and the file is working normally and is not corrupted.
