C284e User Authentication
  • copyman
    Owner / Technician
    • Sep 2005
    • 4702
    Never seen this before. Must have some high security or something?
    I tried turning off in admin mode but it is grayed out. Looking on web interface page it shows "User Authentication On (External Server)"
    Also when powering on machine the screen has message "preparing to connect to external server, please wait" and 3 boxes with authentication device & access basic screen boxes highlighted.
    I've looked everywhere and cannot find how to turn it off! What did I miss?
    Thanks for the help
  • Synthohol
    Certified Konica Expert
    • 5825
    Re: C284e User Authentication
    service mode stop9 vendor mode and delete the card reader driver
    • tsbservice
      Field tech
      • 8016
      Turn off user auth and account track in admin mode... Man you're killing us with so small pics
      • tulintron
        • Jul 2014
        • 668
        +1
        +1
        • copyman
          Owner / Technician
          • Sep 2005
          • 4702
          Wish it was that simple but you must of missed in my OP that it is "grayed out" in admin mode and can't be changed.
          Sorry for small pics. Taken with phone.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4702
            OK, just called the customer and had them go into billing / management setting and they sent me attached pic (sorry again for small pic). I compared to a "4" series in shop and this screen is completely different with no tab to "unset"
            Like I mentioned in OP there must be some high security setting. I've turned off many auth settings with lease returned machines and have never seen this?
            Any other ideas appreciated.....
            Thanks in advance
            • emujo2
              • Mar 2017
              • 1579
              Go into service mode and check your authentication device settings. If it is or was on CARD 3, then my guess is you bought this used and it has been CAC/PIV'd. If so save us some trouble and search the site for how to get rid of this. E
              • and
                • Oct 2011
                • 96
                Check SW 12
                Addition of the authentication device
                Settings(Enabled/Disabled) of Card authentication device for PKI(Card3)
                DipSw No.12 (bit 1)
                0x00 : Disabled (default)
                0x02 : Enabled (Added Card3 key)
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4702
                  Ha-ha, what do you mean save us some trouble? I always search this site before posting. Only thing I could find was the general stuff about turning off in admin mode which I already know about and grayed out. This is why I posted my question. Yes message on screen does mention card 3 and yes machine was a used machine. Not sure if what "and" posted after your post is the solution but if not can I trouble you for the solution?
                  • Synthohol
                    • 5825
                    And is correct.
                    When using the authentication device including AU-102 and AU-201, the loadable device driver needs to be installed.• I.12.15.29 Driver InstallE.1.3.1.(3) IC card information setting procedures
                    Card Uses IC card authentication system (AU-201/SCL-010/AU-201H/AU-202H/YSoft card reader/ OMNIKEY 5427CK (AU-205H))
                    Body Uses biometrics (finger vein) authentication system (AU-102)
                    Card 3 Uses IC card authentication device for PKI card system
                    • When selecting [Body], set a film timeout interval, capture trial time and authentication trial time.• When selecting [Card], a response timeout interval is displayed. (The interval is unchangeable.)• [Card 3] will be displayed only when the following setting shows that switch No.12 is set to [00000010] at Bit assignment/[02] at HEXassignment.[Service Mode] -> [System 2] -> [Software Switch Setting]
                    just my suggestion, get a printout of bit switches from another c284e and what i do (faster than the tool)is just put 1 page on top of another hold it up to the lightand look for different bits engaged.
                    if\when you find them, look them up in the manual before you just assume they ALL should match.
                    also delete the driver for the card reader if its still there.
                    best luck!!
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4702
                      best luck!!
                      [/QUOTE]
                      Thanks Syn. Great tip with matching up the bit switches printouts !!!!
                      • Synthohol
                        • 5825
                        i tried a couple times to use the tool but this was is much faster than even booting up my laptop.
                        hope you find something simple.
                        • tsbservice
                          Field tech
                          • 8016
                          Using a tool with already known good working machine S1 file as target vs offending machine S1 is great 😃
                          However I know most of the switches that are different and why but that just takes few of them to compare and you get used to it.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4702
                            Soft sw 12 worked !!! Was able to go into mgt settings and "unset" then into admin mode and turn off authentication. All good now!
                            1st time I saw an off lease machine with card 3, and hope the last
                            Thanks again to everyone
                            • emujo2
                              • Mar 2017
                              • 1579
                              What I meant was this particular issue has been posted and solved at least 3 times in the last year or so..I was suggesting you search the site for CAC/PIV instead of everyone doing the work to post what has already been posted numerous times. E
