Konica minopta C658 PSWC
  • Kenny
    • Jun 2009
    • 533
    Hi guys,
    Got x2 C658s that will not load the Web browser page, I just get a page saying unable to connect, now I have x3 onsite x1 can log in but x2 can't, I've cleared all data, updated firmware to latest, adjusted the network speeds, I've made sure PSWC is turned on via security settings and HTTP settings,
    Any help would be appreciated driving me nuts
  • emujo2
    • Mar 2017
    • 1579
    Re: Konica minopta C658 PSWC
    I would start with latest firmware, or at least match the one that works, then a network setting clear and rebuild the SSL cert with the machine on the network and pulling an address, then enable SSL once again. Connect directly to the device and clear the browser cache to avoid some kind of stuck info in the browser. E
    • tsbservice
      Field tech
      • 8052
      May work if you use http not HTTPS. Also try different browser. What you have checked under security settings for SSL versions?
      • kingarthur
        • 1385
        I've had a few weird ones - I've discovered in our showroom, if I use 2 particular IP addresses, I can't connect via Chrome, only through IE
        • tsbservice
          Field tech
          • 8052
          Originally posted by Kenny
          Hi guys,
          Kenny I'm curious if you find why web connection isn't working. Please follow up if possible.
          • Synthohol
            Certified Konica Expert
            • 5892
            does it PING?
            enable the web browser on the copier and try 127.0.0.1 and see if pswc opens.
            it should or the firmware is broken?
