Konica Minolta 250i accordion paper after fuser
  • Mitch Barron
    • Mar 2013
    • 180
    DCB734F9-AD16-4D48-938C-31ED7FE94E28.jpgHow is going fellows, hope you guys can advise me or help me with this problem, client call last week with this problem it said and show me the paper but I have never see the machine doing it, that this happen here and there not always,when printing the paper comes out as accordion. I have change pickup drive and fuser but today call again after 9 days that the machine have no problems, and the funny things is that there is no error code or paper jam.
    so any help from you guy to check or had this happened to any one of you.
  • Mitch Barron
    • Mar 2013
    • 180
    Re: Konica Minolta 250i accordion paper after fuser
    Any one with any advice? this is driving me crazy, I was thinking may be is just the paper, so I will bring a new paper to test it for a week and see what happens.
    • REGSIS
      • May 2016
      • 435
      I would start with checking paper type. If paper in the drawer is plain and customer set it on Thick3, after a few continuous pages this could be result (plain paper is overheated)
      Also a flat silicone roller inside fuser can cause this. Check this on site.
      • Mitch Barron
        • Mar 2013
        • 180
        I have done all that with the the paper type, and set a new fuser. but continue happening not always like I had say, last time I was there was 9 days ago since I changed the fuser so everything was ok for that time till yesterday call again same problem but is only one time then I happen no more.
        • occus
          • 338
          Are there no error codes in service mode? Jam 32-02 or so?
          Does the paper stuck in the fuser or after in the duplex switching guide?
          If the paper doesnt go trough the fuser maybe you have damp paper.
          Print 20 pages and search for water drops.
          • Mitch Barron
            • Mar 2013
            • 180
            Occus, the paper goes normal, it passes the fuser and after the exit unit comes the accordion paper as per the client, as I said I havent see the machine doing this but he is the one that tells me and shows me the paper, when I am there I tested printing 100 pages one side and 50 double sides and I get no problems, I check service mode for jams of problems and there is not a single problem or code. that is why this drive me crazy, I am keeping cheking the manual and also I was thinking maybe is a clutch or motor from the exit unit, because as he said the paper goes thrughout the fuser and comes out of the exit unit as accordion.
            • tulintron
              • Jul 2014
              • 668
              Your problem is above the fuser unit, right after the fuser unit. Some exit roller is holding the paper causing this problem. It's worth disassembling and cleaning, looking to see if you can find anything that shows the problem.
              • Mitch Barron
                • Mar 2013
                • 180
                I was thinking the same but what holds me to disassembling is that this is not a always thing, it happens here and there after amount of days, last time that it happened was 10 days, so for now I have bring new paper to the client, may be the paper he is using doesnt seem like a good paper, the box has no brand only says 90 grms, but seems ticker to me. so I will test with this paper is that happens again I will opt for switching the exit unit.
                • tsbservice
                  Field tech
                  • 8052
                  I would bring with me a ream or two of paper and just crush the hell out of the machine testing it.
                  Not the first time we are chasing ghosts of good working machine 😂
                  • Oso
                    • Jan 2024
                    • 13
                    Is this happening in the horizontal paper transport area?
                    • allan
                      RTFM!!
                      • 5462
                      Strip and inspect the switchback unit. Could be a tooth missing from a belt or gear.
                      Whatever
                      • Ziggy
                        • Feb 2018
                        • 801
                        If it has a finisher remove it and the relay unit for a few days to see if that's causing the problem
                        • tech51
                          • 846
                          • tsbservice
                            Field tech
                            • 8052
                            Interesting, typically at what mileage they are seizing?
                            • tech51
                              • 846
