Konica 3100p
  • antone
    • Oct 2014
    • 344
    Konica 3100p
    K toner cartridge...doesn't get recognized! I PUT same cartridge in another machine and it works fine.IU unit is fine contact's are good ect
    Sent from my SM-N981U using Tapatalk
  • Hansoon
    • Sep 2007
    • 3389
    Re: Konica 3100p
    I can not give you a straight answer but based on my experience I have the feeling that if other toner and/or image unit contacts have a problem it might affect the K-cartridge too.
    Hans
    • copier tech
      • 8172
      Re: Konica 3100p
      You could try resetting the K toner count.
      Turn on engine switch with SW59 set to 1. Then Engine SW System 2 SW set to 1 to clear then set back to 0 (this is from memory check the CE manual)
