Konica 300i load 25%
  • konicatoshiba
    • Jan 2023
    • 33
    I have bizhub 300i load 25% panel,can you help!
  • jwai
    • May 2018
    • 508
    Re: Konica 300i load 25%
    check SSD first.
    • copier tech
      • 8142
      You maybe able to recover the device with the recovery tool.
      i Series Boot Up Issues.pdf
      • copytechtrouble
        • Nov 2020
        • 103
        check the SSD first but more likely its the CPU board.
        Technically these machine wont accept a CPU board salvaged from another machine. they'll will display a C-D072 error.
        i had this problem recently and used a salvaged CPU. the machine displayed this error and I left it sitting with the error and after about 20 minutes it rebooted itself and the error had cleared and it worked just fine. not sure how or why but its worth a try...
        • Mr Bo
          • Mar 2023
          • 28
          Try enable DispSW No.34
          • tsbservice
            Field tech
            • 8007
            What this will do and what value?
            • Mr Bo
              • Mar 2023
              • 28
              Sorry,I'm confused
              with this error I replaced the Memory board and uploaded Fw
              • and
                • Oct 2011
                • 96
                You use reset tool for CPU board before the change?
