Bizhub C227
  • Serviceusam
    • Nov 2017
    • 11
    Bizhub C227
    Hello, i have a c227 relatively new (100k prints) that prints with collor strips. I have attached a picture to show you what i mean. I have change the image units, laset unit, reinitialised it, updated the firmware and still prints with the stripes. Any ideas?
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: Bizhub C227
    transfer belt?
    • Serviceusam
      • Nov 2017
      • 11
      Re: Bizhub C227
      i just pulled out the transfer belt, it looks good. i cleaned the sensors beneath it. Same result.
      • Synthohol
        • 5804
        Re: Bizhub C227
        make a solid color page and stop it before it hits the fuser and check the pattern on the belt. that mess has to come from somewhere.
        also the pic is so small,, hard to find details with a postage stamp
        • femaster
          • May 2011
          • 1482
          Re: Bizhub C227
          Those diagonal lines on the black and magenta really are reminiscent of drained developer. Is that picture from after those units were replaced? Really need a larger picture for proper diagnosis.
          • tsbservice
            Field tech
            • 7979
            Re: Bizhub C227
            I think someone messed with color IUs. On this model they're quite expensive and results are tragic.
            Or even K drum bad rebuild may drain developer/s.
            Some kind of exorcist should be good enough to solve the mess if you only find one.
            • Toxic
              • 697
              Re: Bizhub C227
              Picture is small but at lower section you can clearly seen black drum repeating marks.
              Did you rebuild only OPC or you put OEM whole drum units?
              I have some bad expirience with rebuilded units, OEM units is only 100% solution and black unit is not so expensive.
              • Serviceusam
                • Nov 2017
                • 11
                Re: Bizhub C227
                I know the drums are bad, but i do not think that is the problem. If i use the copier on black only, it no longer makes the r y m b marks, it runst normal. It remains only the black drum damage. Te units are oem, not rebuilded.
                • the_teck
                  • Dec 2015
                  • 27
                  Re: Bizhub C227
                  Looks like the CMY unit are over they life span, or even worse, reseted. Don't reset any consumable on C227as they will go berserk very fast. It's better to hide the end life message and run them until no longer possible. A pic of the developing units would be of help.
                  • Mr Bo
                    • Mar 2023
                    • 28
                    Re: Bizhub C227
                    replace Dr214K and Deve K unit, check IU 214M again because the magnetic powder of color M may be lost, Replace genuine toner
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Re: Bizhub C227
                      we had similar looking issues during the great toner shortage.
                      Drum would have residue stuck to the drum when you removed it
                      Also resulted in needing to often also replace the dev, clean out the hopper and install genuine toner
