I series and the print spooler
  • emujo2
    • Mar 2017
    • 1579
    [Misc] I series and the print spooler
    Anyone seen issues with the server print spooler crashing after moving to the Uni driver for the I series?
  • tsbservice
    Field tech
    • 8007
    Re: I series and the print spooler
    Sorry we don't use universal driver.
    • copier tech
      • 8142
      Update the i series firmware & function version then use the PCL 6 driver you won't have any issues.
      • tsbservice
        Field tech
        • 8007
        Yes, this is the way we have been doing most installs for the time being.
        • emujo2
          • Mar 2017
          • 1579
          Thanks for the suggestions, but in this case, the customer feels the Uni drivers are what he wants to use and KM says they work so going to the model specific driver is not an option at the moment. Of course they want the tech to figure this out and keep placing service calls for "spooler crashing"..Fun stuff..
          • Synthohol
            Certified Konica Expert
            • 5822
            is enable spool to HDD enabled on the copier?
            also if using the model specific driver is not an option how in the world is that YOUR problem? (hint, it's not)
            if i can print fine from my laptop with the correct driver that's all the mfg will guarantee usually.
            nobody said you have to support any universal drivers in any contract anywhere.
            sometimes its ok to say it's not my problem and let them figure it out, unless you are their IT dept :
            • tech51
              • 846
              Had this today on an a4 i series. It was suggested to turn off snmp in the port settings.
              This has been done and my customer is going to report back to me if this has made a difference. Interestingly he was getting spooler crashes using the model specific and universal drivers.
