8 Series Dev Conversion
  • Konicatech
    • Feb 2016
    • 133
    Anyone know if its possible to convert a black dev unit for C308 to a colour? i.e using a colour td sensor/chip and running halftones through
  • Brad6784
    • Mar 2015
    • 84
    You certainly can, you need to swap the front bearing or front assembly, very easy to do, a few screws and a e clip from memory.
    • REGSIS
      • May 2016
      • 437
      Re: 8 Series Dev Conversion
      TCR sensor should be the same for K and color like in 4 series.
      • Rad01
        Tech Manager
        • May 2016
        • 27
        Agreed. Can be done but with a little bit of work. Nothing major.
        Have done so a few times in the past when we ran into shortages.
        • copier tech
          • 8222
          This guide may help.
          Konica black to colour dev unit interchangability.pdf
