Software SW No 231 (bit0) -new option
  • cyta123
    • Aug 2015
    • 46
    Hi
    I changed Software SW No 231 : hex:01
    The function that delete the target job when a specific error occurs..
    Software SWNo. 231 0x00: Do not use (default)
    Software SWNo. 231 0x01: Use<<
    Do you know, where new options apear? I am interesting in to delete job after paper is missed.
  • femaster
    • May 2011
    • 1527
    Re: Software SW No 231 (bit0) -new option
    Originally posted by cyta123
    Hi
    Have you checked in the service manual as a starting point? There are a lot of them listed in there.
    Otherwise this thread is also a good source:
    Konica Software Switch settings (complete)
    • cyta123
      • Aug 2015
      • 46
      >>Have you checked in the service manual as a starting point? There are a lot of them listed in there.<<
      SM says nothing about it.
      The only description sw 231 there is in DLKM_BT2116061EN, but seems to be uncomplete.
        • 22994
        Delete jobs when a job stopped due to an error
        Software SW No.231 (bit 0)
        0x00: Disable (Default)
        0x01: Enable
        - "Job Delete Settings" menu is established in "Administrator Settings"
        - "Job Delete mode", "Job Delete Time", and "Job Delete key" settings can be configured in this menu.
        - If "Job Delete key" is enabled, a job stopped due to an error is deleted by touching the "Job Delete" key.
        - If "Job Delete Time setting" is enabled, when an error occurs in MFP,
        the Copy/Print jobs of the authenticated users (including Public user) are deleted.
        - If "Job Delete mode" is set to Mode 1-3, the following types of jobs are deleted.
        - Mode 1
        - The Copy/Print jobs of the authenticated users (including Public user)
        - Print jobs without authenticate
        - Fax receiving jobs
        - Mode 2
        - Mode 3
        - If "Job Delete mode" is set to Mode 4, the timing of delete jobs can be set depending on the types of error.
        - When the job deletion is executed, a warning screen is displayed.
        bizhub C368/C308/C258: DLBT1618151EN
        bizhub 367/287/227(Function version 3.4 or later)
        bizhub C368/C308/C258(Function version 3.4 or later)
        bizhub C287/C227(Function version 3.4 or later)
        bizhub 958/808/758(Function version 3.4 or later)
        bizhub C658/C558/C458(Function version 3.4 or later)
        bizhub 558/458/368/308(Function version 3.4 or later)
        bizhub C3851/C3851FS/C3351(Function version 3.4 or later)
        bizhub C759/C659
        bizhub 368e/308e
        bizhub 658e/558e/458e
        The related SW is as follows:
        Software SWNo.105(0bit)
        Software SWNo.145(7bit)
        Both #105 & #145 come defaulted to "Disabled". =^..^=
        • femaster
          • May 2011
          • 1527
          Sorry, I misunderstood what you were looking for. I thought that you had come across that software switch and that you were looking to find out what other ones were and what they did, not what that specific one was for, as it seemed like you already knew about that one.
          • cyta123
            • Aug 2015
            • 46
            blackcat4866
            Thanks a lot.
            • rrrohan
              • Sep 2011
              • 1973
              Is this for users who send jobs but dont pickup job straight away from holding up the entire print cue due to incorrect paper tray settings or does it only delete job if it jams?
              • cyta123
                • Aug 2015
                • 46
                Take a look at Mode4
