Fiery ic-413 crashes
Re: Fiery ic-413 crashes
When upgrading the frame, rip does not start, everything works as it should, 00 is on the display,
The question is whether the OS needs to be reinstalled to recognize 4 or 8 ram memories, I can't teach remote desktop because I don't know what the Fiery password Fiery. 1 doesn't go throughComment
1. installed the bios
2. replaced the 2x2 gb module
3. replaced hard with W7 sis 1.11
4. does not recognize rip on minolta
5. returned ram to 1x1 mb works
The question is whether the system needs to be reinstalled for more RAM or does it only work on 2 RAM memory,when booting, it correctly says that the bios recognized the memory and 2 ram and 4 gb
Can I have some help?Comment
you import the patch to the direct queue through command workstation.
that will upgrade the motherboard bios.
then proceed with the upgrade but 1.11 needs another disk that comes with the upgrade kit.
that disk is not offered on MKM as its a paid upgrade.
can you log onto it with CWS or its webpage?We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
My question is when I put more ram the rip just doesn't start what to do to make it work with more ram 4gbComment
