Marketplace screensaver
  • mascan42
    • Oct 2008
    • 484
    I have a customer who has a Marketplace app installed, but wants to turn off the screensaver. The screensaver enable button (on the system auto reset screen) is missing. Is there some way to shut that off while leaving Marketplace on?
  • tsbservice
    Field tech
    • 8013
    Re: Marketplace screensaver
    Noticed that some time ago, user manual is wrong telling:
    When using the screen saver function, set this option to ON (default: ON).
    This option is displayed when the MarketPlace application is installed.
      • 23008
      Just out of curiosity, why do you want Marketplace ON? You don't get enough advertisements during the rest of your existence? =^..^=
      • tsbservice
        Field tech
        • 8013
        Unfortunately it's always customers wanting unthinkable things.
        • rrrohan
          • Sep 2011
          • 1977
          it used to be able to be turned off
          you can get rid of it using API manager but im betting it will re install itself
          • Synthohol
            Certified Konica Expert
            • 5824
            There is a bit switch to change
            There is the answer posted here
